LG V50 ThinQ Screen Replacement
    1. LG V50 ThinQ Screen Replacement, Screen: step 1, image 1 of 3 LG V50 ThinQ Screen Replacement, Screen: step 1, image 2 of 3 LG V50 ThinQ Screen Replacement, Screen: step 1, image 3 of 3
      • Flip the phone over, making sure that the back of the phone is facing up.
      • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
      Ask FixBot
    2. LG V50 ThinQ Screen Replacement: step 2, image 1 of 2 LG V50 ThinQ Screen Replacement: step 2, image 2 of 2
      • With the device facing down, remove all 12 1mm Phillips #000 screws.
      • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
      Ask FixBot
    3. LG V50 ThinQ Screen Replacement: step 3, image 1 of 3 LG V50 ThinQ Screen Replacement: step 3, image 2 of 3 LG V50 ThinQ Screen Replacement: step 3, image 3 of 3
      • Remove the two brackets covering the internal components.
      Ask FixBot
    4. LG V50 ThinQ Screen Replacement: step 4, image 1 of 2 LG V50 ThinQ Screen Replacement: step 4, image 2 of 2
      • Remove the battery connection from its connector port, located above the battery.
      • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
      Ask FixBot
    5. LG V50 ThinQ Screen Replacement: step 5, image 1 of 1
      • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
      • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
      • Carefully put the replacement screen into place.
      Ask FixBot
2 other people completed this guide.
Carlos Rivera
148 Reputation
1 Guide authored
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 128
All Time: 1,969
