LG V50 ThinQ Battery Replacement
    1. LG V50 ThinQ Battery Replacement, Battery: step 1, image 1 of 3 LG V50 ThinQ Battery Replacement, Battery: step 1, image 2 of 3 LG V50 ThinQ Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the phone over, so that the back of the phone is facing you.
      • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
      Ask FixBot
    2. LG V50 ThinQ Battery Replacement: step 2, image 1 of 3 LG V50 ThinQ Battery Replacement: step 2, image 2 of 3 LG V50 ThinQ Battery Replacement: step 2, image 3 of 3
      • Remove all twelve 1 mm Phillips #000 screws.
      • Remember to keep the screws in a safe place for reassembly later!
      Ask FixBot
    3. LG V50 ThinQ Battery Replacement: step 3, image 1 of 3 LG V50 ThinQ Battery Replacement: step 3, image 2 of 3 LG V50 ThinQ Battery Replacement: step 3, image 3 of 3
      • Remove the two brackets.
      Ask FixBot
    4. LG V50 ThinQ Battery Replacement: step 4, image 1 of 2 LG V50 ThinQ Battery Replacement: step 4, image 2 of 2
      • DO NOT attempt to remove the phone battery with a metallic/sharp prying object.
      • Disconnect the battery from the phone by removing the battery connection from the connector port.
      • Remove the battery by prying the underside of the battery and pulling upwards with the opening pick (shown in image 2).
      • Do not be too rough with the battery, as it is easy to dent/break into.
      • Now, place the new battery inside the slot, firmly pressing it into the space against the copper-colored heatsink on the bottom.
      Ask FixBot
4 other people completed this guide.
Tanmay Sonawane
271 Reputation
2 Guides authored
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 126
All Time: 2,701
