LG V40 ThinQ Back Cover Replacement
    1. LG V40 ThinQ Back Cover Replacement, Back Cover: step 1, image 1 of 2 LG V40 ThinQ Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Use an iOpener or hairdryer to heat the adhesive on the back cover by rolling it up and down the back of the phone.
      • You will know when the back is hot enough when an Opening pick is able to slide under the back cover.
      Ask FixBot
    2. LG V40 ThinQ Back Cover Replacement: step 2, image 1 of 3 LG V40 ThinQ Back Cover Replacement: step 2, image 2 of 3 LG V40 ThinQ Back Cover Replacement: step 2, image 3 of 3
      • Use opening to pry the back cover away from the adhesive.
      • This can take some time. Be patient and go slowly.
      • We recommend you move slowly and carefully to not crack the back glass.
      Ask FixBot
    3. LG V40 ThinQ Back Cover Replacement: step 3, image 1 of 2 LG V40 ThinQ Back Cover Replacement: step 3, image 2 of 2
      • Carefully disconnect the fingerprint sensor from the back camera lens cover.
      Ask FixBot
    4. LG V40 ThinQ Back Cover Replacement: step 4, image 1 of 3 LG V40 ThinQ Back Cover Replacement: step 4, image 2 of 3 LG V40 ThinQ Back Cover Replacement: step 4, image 3 of 3
      • Use the opening picks again to gently remove the back camera lens cover and fingerprint sensor off from the back cover.
      • Set the fingerprint sensor and camera cover aside. You will need the fingerprint sensor to put into any new back cover bought for the phone.
      Ask FixBot
    5. LG V40 ThinQ Back Cover Replacement: step 5, image 1 of 2 LG V40 ThinQ Back Cover Replacement: step 5, image 2 of 2
      • Clean the back cover of any old adhesive by gently heating the area with the iOpener to soften the adhesive.
      • Use a cloth or cotton swab soaked in isopropyl alcohol to gently rub and dissolve the glue.
      Ask FixBot
    6. LG V40 ThinQ Back Cover Replacement: step 6, image 1 of 1
      • Apply new adhesive on the back cover in the places where the old adhesive was applied.
      Ask FixBot
Noah
538 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 73
All Time: 399
