LG V40 ThinQ Power/Volume Buttons Replacement
    1. LG V40 ThinQ  Power/Volume Buttons Replacement, Back Cover: step 1, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement, Back Cover: step 1, image 2 of 2
      • Use an iOpener or hairdryer to heat the adhesive on the back cover by rolling it up and down the back of the phone.
      • You will know when the back is hot enough when an Opening pick is able to slide under the back cover.
      Ask FixBot
    2. LG V40 ThinQ  Power/Volume Buttons Replacement: step 2, image 1 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 2, image 2 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 2, image 3 of 3
      • Use opening to pry the back cover away from the adhesive.
      • This can take some time. Be patient and go slowly.
      • We recommend you move slowly and carefully to not crack the back glass.
      Ask FixBot
    3. LG V40 ThinQ  Power/Volume Buttons Replacement: step 3, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement: step 3, image 2 of 2
      • Carefully disconnect the fingerprint sensor from the back camera lens cover.
      Ask FixBot
    4. LG V40 ThinQ  Power/Volume Buttons Replacement: step 4, image 1 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 4, image 2 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 4, image 3 of 3
      • Use the opening picks again to gently remove the back camera lens cover and fingerprint sensor off from the back cover.
      • Set the fingerprint sensor and camera cover aside. You will need the fingerprint sensor to put into any new back cover bought for the phone.
      Ask FixBot
    5. LG V40 ThinQ  Power/Volume Buttons Replacement: step 5, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement: step 5, image 2 of 2
      • Clean the back cover of any old adhesive by gently heating the area with the iOpener to soften the adhesive.
      • Use a cloth or cotton swab soaked in isopropyl alcohol to gently rub and dissolve the glue.
      Ask FixBot
    6. LG V40 ThinQ  Power/Volume Buttons Replacement: step 6, image 1 of 1
      • Apply new adhesive on the back cover in the places where the old adhesive was applied.
      Ask FixBot
    1. LG V40 ThinQ  Power/Volume Buttons Replacement, Battery: step 7, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement, Battery: step 7, image 2 of 2
      • Remove the fourteen 15 mm-long Phillips #000 screws holding down the wireless charging coil and loudspeaker module.
      Ask FixBot
    2. LG V40 ThinQ  Power/Volume Buttons Replacement: step 8, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement: step 8, image 2 of 2
      • Disconnect the battery press connector.
      Ask FixBot
    3. LG V40 ThinQ  Power/Volume Buttons Replacement: step 9, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement: step 9, image 2 of 2
      • With the opening picks, very gently insert and pry the battery slowly until it comes free from the adhesive and remove it.
      • This can take some time to safely remove the battery without damaging it. Be careful not to rip the battery from the adhesive holding it down.
      Ask FixBot
    1. LG V40 ThinQ  Power/Volume Buttons Replacement, Power/Volume Buttons: step 10, image 1 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement, Power/Volume Buttons: step 10, image 2 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement, Power/Volume Buttons: step 10, image 3 of 3
      • Use opening picks to detach the motherboard cables.
      • Remove the motherboard.
      Ask FixBot
    2. LG V40 ThinQ  Power/Volume Buttons Replacement: step 11, image 1 of 2 LG V40 ThinQ  Power/Volume Buttons Replacement: step 11, image 2 of 2
      • Disconnect both flex cables from the button sensors to avoid scratching and damaging them while prying with the Jimmy tool.
      Ask FixBot
    3. LG V40 ThinQ  Power/Volume Buttons Replacement: step 12, image 1 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 12, image 2 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 12, image 3 of 3
      • Using the Jimmy, gently remove the power and volume buttons.
      • The Jimmy can be very sharp. It can slip and you can cut your self.
      Ask FixBot
    4. LG V40 ThinQ  Power/Volume Buttons Replacement: step 13, image 1 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 13, image 2 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 13, image 3 of 3
      • Remove the tape covering the power button.
      • Using the Angled ESD precision Tweezers, remove the power button.
      Ask FixBot
    5. LG V40 ThinQ  Power/Volume Buttons Replacement: step 14, image 1 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 14, image 2 of 3 LG V40 ThinQ  Power/Volume Buttons Replacement: step 14, image 3 of 3
      • Remove the tape covering the volume buttons.
      • Using the Angled ESD precision Tweezers, remove the volume buttons.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 89
All Time: 456
