Up to 20% off select tools
LG V30 Rear Camera Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
97
All Time:
3,181
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
In this video, I will show you how to replace LG V30 standard or wide-angle back camera.
This guide will show you how to replace both the standard and wide-angle rear cameras in the LG V30 smartphone. If your rear cameras are producing blurry or glitchy photos, or if your cameras are failing to function at all, replacing them should alleviate your issues.
Video Overview
    1. LG V30 Rear Camera Replacement, Rear Camera: step 1, image 1 of 3 LG V30 Rear Camera Replacement, Rear Camera: step 1, image 2 of 3 LG V30 Rear Camera Replacement, Rear Camera: step 1, image 3 of 3
      • Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
      • Pull the SIM card tray out from the phone.
      Ask FixBot
    2. LG V30 Rear Camera Replacement: step 2, image 1 of 2 LG V30 Rear Camera Replacement: step 2, image 2 of 2
      • Use a heat gun to apply heat to the back cover.
      Ask FixBot
    3. LG V30 Rear Camera Replacement: step 3, image 1 of 3 LG V30 Rear Camera Replacement: step 3, image 2 of 3 LG V30 Rear Camera Replacement: step 3, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Use a suction cup to lift up the back cover up.
      • Insert the edge of a plastic card into the space created between the cover and frame.
      Ask FixBot
    4. LG V30 Rear Camera Replacement: step 4, image 1 of 3 LG V30 Rear Camera Replacement: step 4, image 2 of 3 LG V30 Rear Camera Replacement: step 4, image 3 of 3
      • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
      Ask FixBot
    5. LG V30 Rear Camera Replacement: step 5, image 1 of 3 LG V30 Rear Camera Replacement: step 5, image 2 of 3 LG V30 Rear Camera Replacement: step 5, image 3 of 3
      • Continue to slide the cards around the remaining three edges to release the adhesive.
      Ask FixBot
    6. LG V30 Rear Camera Replacement: step 6, image 1 of 3 LG V30 Rear Camera Replacement: step 6, image 2 of 3 LG V30 Rear Camera Replacement: step 6, image 3 of 3
      • Remove the back cover.
      Ask FixBot
    7. LG V30 Rear Camera Replacement: step 7, image 1 of 1
      • Remove the ten Phillips #000 screws from the midframe.
      Ask FixBot
    8. LG V30 Rear Camera Replacement: step 8, image 1 of 3 LG V30 Rear Camera Replacement: step 8, image 2 of 3 LG V30 Rear Camera Replacement: step 8, image 3 of 3
      • Using a plastic spudger, pry up the midframe of the phone.
      Ask FixBot
    9. LG V30 Rear Camera Replacement: step 9, image 1 of 2 LG V30 Rear Camera Replacement: step 9, image 2 of 2
      • Remove the midframe.
      Ask FixBot
    10. LG V30 Rear Camera Replacement: step 10, image 1 of 3 LG V30 Rear Camera Replacement: step 10, image 2 of 3 LG V30 Rear Camera Replacement: step 10, image 3 of 3
      • Use the plastic spudger to pry up the four press fit connectors on the top portion of the motherboard.
      Ask FixBot
    11. LG V30 Rear Camera Replacement: step 11, image 1 of 3 LG V30 Rear Camera Replacement: step 11, image 2 of 3 LG V30 Rear Camera Replacement: step 11, image 3 of 3
      • Pry up the speaker panel with a plastic spudger and remove it from the phone.
      Ask FixBot
    12. LG V30 Rear Camera Replacement: step 12, image 1 of 3 LG V30 Rear Camera Replacement: step 12, image 2 of 3 LG V30 Rear Camera Replacement: step 12, image 3 of 3
      • Use a spudger to pry up the two press fit connectors on the bottom portion of the midframe.
      Ask FixBot
    13. LG V30 Rear Camera Replacement: step 13, image 1 of 3 LG V30 Rear Camera Replacement: step 13, image 2 of 3 LG V30 Rear Camera Replacement: step 13, image 3 of 3
      • Use a spudger to pry up the motherboard and lift it out of the phone's frame.
      Ask FixBot
    14. LG V30 Rear Camera Replacement: step 14, image 1 of 3 LG V30 Rear Camera Replacement: step 14, image 2 of 3 LG V30 Rear Camera Replacement: step 14, image 3 of 3
      • Flip over the motherboard.
      • Using a plastic spudger, pry up the press fit connector for the first camera.
      Ask FixBot
    15. LG V30 Rear Camera Replacement: step 15, image 1 of 2 LG V30 Rear Camera Replacement: step 15, image 2 of 2
      Buy
      • Remove the camera with a pair of ESD safe tweezers.
      Ask FixBot
    16. LG V30 Rear Camera Replacement: step 16, image 1 of 3 LG V30 Rear Camera Replacement: step 16, image 2 of 3 LG V30 Rear Camera Replacement: step 16, image 3 of 3
      • Pry up the second camera with a spudger.
      • The press fit connector has already been disconnected, but the camera module is still lightly adhered to the motherboard.
      • Remove the second camera with a pair of tweezers.
      Ask FixBot
2 other people completed this guide.
Author
with
Witrigs
71,202 Reputation
376 Guides authored
1 Guide Comment
Does this make it no longer waterproof?
Rob Hoover - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 97
All Time: 3,181
