LG V30 Plus Rear Glass Replacement
    1. LG V30 Plus Rear Glass Replacement, Rear Glass: step 1, image 1 of 1
      • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
      • Allow to sit for 1-2 minutes to heat up the adhesive.
      • A heat gun may need to be used if you have trouble separating the backing in the next step.
      Ask FixBot
    2. LG V30 Plus Rear Glass Replacement: step 2, image 1 of 2 LG V30 Plus Rear Glass Replacement: step 2, image 2 of 2
      • Insert an Opening Tool into the seam between the rear glass and side of the phone.
      • Pry the glass off just enough to insert an Opening Pick.
      • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
      Ask FixBot
    3. LG V30 Plus Rear Glass Replacement: step 3, image 1 of 1
      • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
      Ask FixBot
Geoffrey Smith
416 Reputation
3 Guides authored
Cal Poly, Team S1-G3, Maness Spring 2019 Member of Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 72
All Time: 1,705
