LG V30 Plus Motherboard Replacement
    1. LG V30 Plus Motherboard Replacement, Rear Glass: step 1, image 1 of 1
      • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
      • Allow to sit for 1-2 minutes to heat up the adhesive.
      • A heat gun may need to be used if you have trouble separating the backing in the next step.
      Ask FixBot
    2. LG V30 Plus Motherboard Replacement: step 2, image 1 of 2 LG V30 Plus Motherboard Replacement: step 2, image 2 of 2
      • Insert an Opening Tool into the seam between the rear glass and side of the phone.
      • Pry the glass off just enough to insert an Opening Pick.
      • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
      Ask FixBot
    3. LG V30 Plus Motherboard Replacement: step 3, image 1 of 1
      • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
      Ask FixBot
    1. LG V30 Plus Motherboard Replacement, Motherboard: step 4, image 1 of 2 LG V30 Plus Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
      Ask FixBot
    2. LG V30 Plus Motherboard Replacement: step 5, image 1 of 3 LG V30 Plus Motherboard Replacement: step 5, image 2 of 3 LG V30 Plus Motherboard Replacement: step 5, image 3 of 3
      • Gently push down on the small black tab with a Spudger to release the protective board.
      • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
      • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
      Ask FixBot
    3. LG V30 Plus Motherboard Replacement: step 6, image 1 of 2 LG V30 Plus Motherboard Replacement: step 6, image 2 of 2
      • Slide an Opening Tool between the lower protective board and the phone to unclip.
      • Slide the tool along the remaining edges of the protective board until it pops off.
      Ask FixBot
    4. LG V30 Plus Motherboard Replacement: step 7, image 1 of 2 LG V30 Plus Motherboard Replacement: step 7, image 2 of 2
      • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
      Ask FixBot
    5. LG V30 Plus Motherboard Replacement: step 8, image 1 of 1
      • Gently remove the motherboard from the phone.
      Ask FixBot
Geoffrey Smith
416 Reputation
3 Guides authored
Cal Poly, Team S1-G3, Maness Spring 2019 Member of Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Members
60 Guides authored
1 Guide Comment
I followed these instructions and now my phone’s touchscreen is unresponsive. The phone turns off and on by holding the power button, and the screen displays the image properly, but it won’t respond to touch to unlock it.
Julian Marley - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 38
All Time: 1,712
