LG V30 Plus Front-Facing Camera Replacement
    1. LG V30 Plus Front-Facing Camera Replacement, Rear Glass: step 1, image 1 of 1
      • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
      • Allow to sit for 1-2 minutes to heat up the adhesive.
      • A heat gun may need to be used if you have trouble separating the backing in the next step.
      Ask FixBot
    2. LG V30 Plus Front-Facing Camera Replacement: step 2, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement: step 2, image 2 of 2
      • Insert an Opening Tool into the seam between the rear glass and side of the phone.
      • Pry the glass off just enough to insert an Opening Pick.
      • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
      Ask FixBot
    3. LG V30 Plus Front-Facing Camera Replacement: step 3, image 1 of 1
      • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
      Ask FixBot
    1. LG V30 Plus Front-Facing Camera Replacement, Motherboard: step 4, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement, Motherboard: step 4, image 2 of 2
      • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
      Ask FixBot
    2. LG V30 Plus Front-Facing Camera Replacement: step 5, image 1 of 3 LG V30 Plus Front-Facing Camera Replacement: step 5, image 2 of 3 LG V30 Plus Front-Facing Camera Replacement: step 5, image 3 of 3
      • Gently push down on the small black tab with a Spudger to release the protective board.
      • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
      • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
      Ask FixBot
    3. LG V30 Plus Front-Facing Camera Replacement: step 6, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement: step 6, image 2 of 2
      • Slide an Opening Tool between the lower protective board and the phone to unclip.
      • Slide the tool along the remaining edges of the protective board until it pops off.
      Ask FixBot
    4. LG V30 Plus Front-Facing Camera Replacement: step 7, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement: step 7, image 2 of 2
      • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
      Ask FixBot
    5. LG V30 Plus Front-Facing Camera Replacement: step 8, image 1 of 1
      • Gently remove the motherboard from the phone.
      Ask FixBot
    1. LG V30 Plus Front-Facing Camera Replacement, Battery: step 9, image 1 of 3 LG V30 Plus Front-Facing Camera Replacement, Battery: step 9, image 2 of 3 LG V30 Plus Front-Facing Camera Replacement, Battery: step 9, image 3 of 3
      • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
      • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
      • Insert Opening Picks if needed to keep the battery elevated.
      Ask FixBot
    1. LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: step 10, image 1 of 2 LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: step 10, image 2 of 2
      • Use a Spudger to pry away the front-facing camera from the board.
      Ask FixBot
Samuel Jahnke
282 Reputation
2 Guides authored
Cal Poly, Team S1-G3, Maness Spring 2019 Member of Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 63
All Time: 697
