Up to 20% off select tools
LG V30 Plus Battery Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
86
All Time:
2,817
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your device isn’t turning on even after a charge, the battery may be faulty. Before you remove the battery, be advised that there may be a strong adhesive holding the battery with the phone. Use this guide to replace the battery in your device.
    1. LG V30 Plus Battery Replacement, Rear Glass: step 1, image 1 of 1
      • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
      • Allow to sit for 1-2 minutes to heat up the adhesive.
      • A heat gun may need to be used if you have trouble separating the backing in the next step.
      Ask FixBot
    2. LG V30 Plus Battery Replacement: step 2, image 1 of 2 LG V30 Plus Battery Replacement: step 2, image 2 of 2
      • Insert an Opening Tool into the seam between the rear glass and side of the phone.
      • Pry the glass off just enough to insert an Opening Pick.
      • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
      Ask FixBot
    3. LG V30 Plus Battery Replacement: step 3, image 1 of 1
      • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
      Ask FixBot
    1. LG V30 Plus Battery Replacement, Motherboard: step 4, image 1 of 2 LG V30 Plus Battery Replacement, Motherboard: step 4, image 2 of 2
      • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
      Ask FixBot
    2. LG V30 Plus Battery Replacement: step 5, image 1 of 3 LG V30 Plus Battery Replacement: step 5, image 2 of 3 LG V30 Plus Battery Replacement: step 5, image 3 of 3
      • Gently push down on the small black tab with a Spudger to release the protective board.
      • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
      • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
      Ask FixBot
    3. LG V30 Plus Battery Replacement: step 6, image 1 of 2 LG V30 Plus Battery Replacement: step 6, image 2 of 2
      • Slide an Opening Tool between the lower protective board and the phone to unclip.
      • Slide the tool along the remaining edges of the protective board until it pops off.
      Ask FixBot
    4. LG V30 Plus Battery Replacement: step 7, image 1 of 2 LG V30 Plus Battery Replacement: step 7, image 2 of 2
      • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
      Ask FixBot
    5. LG V30 Plus Battery Replacement: step 8, image 1 of 1
      • Gently remove the motherboard from the phone.
      Ask FixBot
    1. LG V30 Plus Battery Replacement, Battery: step 9, image 1 of 3 LG V30 Plus Battery Replacement, Battery: step 9, image 2 of 3 LG V30 Plus Battery Replacement, Battery: step 9, image 3 of 3
      • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
      • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
      • Insert Opening Picks if needed to keep the battery elevated.
      Ask FixBot
Author
with
Samuel Jahnke
282 Reputation
2 Guides authored
Cal Poly, Team S1-G3, Maness Spring 2019 Member of Cal Poly, Team S1-G3, Maness Spring 2019
CPSU-MANESS-S19S1G3
4 Members
60 Guides authored
1 Guide Comment
I did this and now my phone’s touch screen is unresponsive. The power button and volume buttons work and the phone turns on, but I cannot unlock my phone due to the touch screen not responding
Julian Marley - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 86
All Time: 2,817
