Up to 20% off select tools
LG V30 Battery Replacement
Views: 33K
View statistics:
Past 24 Hours:
5
Past 7 Days:
44
Past 30 Days:
248
All Time:
33,261
Comments: 13
1 comment on steps, 12 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in the LG V30 (and V30+) smartphone. If your battery is draining too quickly or has stopped charging fully, replacing the battery should alleviate your issues.
This guide involves removing the back cover of your device, so you will need replacement adhesive to reattach the back cover to the phone. This guide also involves removing the battery of your device, which is attached to the inside of the phone using adhesive. You will need replacement adhesive to reattach the battery to the inside of the phone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion are decreased.
Alternatively, use this LG V30 Battery Replacement video to replace the battery in your LG V30 smartphone.
Video Overview
LG V30 Battery Repair Guide
    1. LG V30 Battery Replacement, Power Off: step 1, image 1 of 3 LG V30 Battery Replacement, Power Off: step 1, image 2 of 3 LG V30 Battery Replacement, Power Off: step 1, image 3 of 3
      • Drain the battery's charge below 25%.
      • Power off the phone by pressing and holding the Power/Lock key on the backside of the phone for three seconds. Tap the Power Off option and Power Off to confirm.
      Ask FixBot
    2. LG V30 Battery Replacement, Remove SIM Tray/Card: step 2, image 1 of 3 LG V30 Battery Replacement, Remove SIM Tray/Card: step 2, image 2 of 3 LG V30 Battery Replacement, Remove SIM Tray/Card: step 2, image 3 of 3
      • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the phone.
      • Press gently to eject the SIM tray.
      • Remove the SIM card tray from the device.
      • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
      Ask FixBot
    3. LG V30 Battery Replacement, Heat Backing's Adhesive: step 3, image 1 of 1
      • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
      • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. See the iOpener instructions guide to learn how to use an iOpener.
      • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
      • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
      Ask FixBot
    4. LG V30 Battery Replacement: step 4, image 1 of 3 LG V30 Battery Replacement: step 4, image 2 of 3 LG V30 Battery Replacement: step 4, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Use a suction cup to lift up the back cover up.
      • Insert the edge of a plastic card into the space created between the cover and frame.
      Ask FixBot
    5. LG V30 Battery Replacement: step 5, image 1 of 3 LG V30 Battery Replacement: step 5, image 2 of 3 LG V30 Battery Replacement: step 5, image 3 of 3
      • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
      Ask FixBot
    6. LG V30 Battery Replacement: step 6, image 1 of 3 LG V30 Battery Replacement: step 6, image 2 of 3 LG V30 Battery Replacement: step 6, image 3 of 3
      • Continue to slide the cards around the remaining three edges to release the adhesive.
      Ask FixBot
    7. LG V30 Battery Replacement, Remove Back Cover: step 7, image 1 of 3 LG V30 Battery Replacement, Remove Back Cover: step 7, image 2 of 3 LG V30 Battery Replacement, Remove Back Cover: step 7, image 3 of 3
      • Carefully remove the back cover, making sure that the adhesive is sliced through on all sides.
      • Because this phone's backing is attached using adhesive, you will need to replace the adhesive when re-assembling the phone.
      Ask FixBot
    8. LG V30 Battery Replacement: step 8, image 1 of 1
      • Remove the ten Phillips #000 screws from the midframe.
      Ask FixBot
    9. LG V30 Battery Replacement: step 9, image 1 of 3 LG V30 Battery Replacement: step 9, image 2 of 3 LG V30 Battery Replacement: step 9, image 3 of 3
      • Using a plastic spudger, pry up the midframe of the phone.
      Ask FixBot
    10. LG V30 Battery Replacement, Remove Midframe: step 10, image 1 of 2 LG V30 Battery Replacement, Remove Midframe: step 10, image 2 of 2
      • Carefully pull the midframe from the rest of the phone's body.
      • The midframe is connected to the main body with a small slot on the right side of the midframe. Carefully free the frame from this slot by gently wiggling and pulling outwards at the same time.
      Ask FixBot
    11. LG V30 Battery Replacement: step 11, image 1 of 3 LG V30 Battery Replacement: step 11, image 2 of 3 LG V30 Battery Replacement: step 11, image 3 of 3
      • Use the plastic spudger to pry up the four press-fit connectors on the top portion of the motherboard.
      Ask FixBot
    12. LG V30 Battery Replacement, Remove Speaker Assembly: step 12, image 1 of 3 LG V30 Battery Replacement, Remove Speaker Assembly: step 12, image 2 of 3 LG V30 Battery Replacement, Remove Speaker Assembly: step 12, image 3 of 3
      • Pry up the speaker panel with a plastic spudger and remove it from the phone.
      Ask FixBot
    13. LG V30 Battery Replacement: step 13, image 1 of 1
      • Use a heat gun to apply heat to the front face of the phone. This will soften the adhesive used to secure the phone's battery.
      • When using a heat gun or hair dryer to soften the adhesive, be careful not to overheat the battery. The hair dryer/heat gun will make the phone hot to the touch, so handle the phone with care.
      • Alternatively, you can place a heated iOpener across the top of the battery for approximately three minutes to soften the adhesive holding the battery to the device.
      • If you have multiple iOpeners, it is recommended to also put one on the screen side of the battery.
      Ask FixBot
    14. LG V30 Battery Replacement: step 14, image 1 of 3 LG V30 Battery Replacement: step 14, image 2 of 3 LG V30 Battery Replacement: step 14, image 3 of 3
      • Insert a plastic card at the bottom edge of the battery
      • Gently work the plastic card around the left side of the battery, separating the battery from its adhesive.
      Ask FixBot
    15. LG V30 Battery Replacement, Remove Battery: step 15, image 1 of 3 LG V30 Battery Replacement, Remove Battery: step 15, image 2 of 3 LG V30 Battery Replacement, Remove Battery: step 15, image 3 of 3
      • Use the plastic card to pry the battery upwards from its slot.
      • Use your fingers to lift the battery away from the phone.
      • Because this battery is attached using adhesive, you will need to replace the adhesive when installing a new battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. After installing a new battery, run down its charge completely. Then, charge the battery fully. This will calibrate the new battery. Then, use the phone normally.
14 other people completed this guide.
Author
with
Witrigs
71,202 Reputation
376 Guides authored
12 Guide Comments
Do you have to put the adhesive for the battery?
RT RT - Reply Share
Suction cups on both sides, heatgun on the back pannel, then lift. Much easier. And you don't have to worry about breaking the back panel.
DJ Somebody - Reply Share
Why can’t the idiots at LG, or indeed any other company, make a phone with an MQA capable DAC, and a replaceable battery?
tonywinter - Reply Share
it is not about idiocy. When you do not conform to a set battery shape you can configure the insides of a phone for more performance and features. That being said the LG V30 does have a standard battery shape. So in this case it is a desire to create built in obsolescence. After all it is believed in the western world cell phone sales are flat.
Malinourn Malinourn - Reply Share
And..as long as the battery is in the phone it can be used to track you…
Loud Harley - Reply Share
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 248
All Time: 33,261
