Up to 20% off select tools
LG V20 Volume Button Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
105
All Time:
4,069
Comments: 5
5 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Exposure to dirt or the shock of dropping a phone can damage volume buttons and cause them to become unresponsive. This guide will lead you through all the steps required to get your LG V20's volume button out of the phone and ready for replacement.
    1. LG V20 Volume Button Replacement, Battery: step 1, image 1 of 3 LG V20 Volume Button Replacement, Battery: step 1, image 2 of 3 LG V20 Volume Button Replacement, Battery: step 1, image 3 of 3
      • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
      • Be careful not to deform or puncture the battery.
      • Pry up and remove the battery.
      Ask FixBot
    1. LG V20 Volume Button Replacement, Midframe Assembly: step 2, image 1 of 1
      • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
      Ask FixBot
    2. LG V20 Volume Button Replacement: step 3, image 1 of 2 LG V20 Volume Button Replacement: step 3, image 2 of 2
      • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
      • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
      Ask FixBot
    3. LG V20 Volume Button Replacement: step 4, image 1 of 2 LG V20 Volume Button Replacement: step 4, image 2 of 2
      • Flip the phone and insert an opening pick in the gap you created.
      • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
      Ask FixBot
    4. LG V20 Volume Button Replacement: step 5, image 1 of 1
      • Remove the frame section.
      • Repeat this procedure with the frame section on the other end of the phone.
      • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
      Ask FixBot
    5. LG V20 Volume Button Replacement: step 6, image 1 of 2 LG V20 Volume Button Replacement: step 6, image 2 of 2
      • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
      Ask FixBot
    6. LG V20 Volume Button Replacement: step 7, image 1 of 2 LG V20 Volume Button Replacement: step 7, image 2 of 2
      • The cover of the motherboard is held in its place by several plastic clamps.
      • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
      Ask FixBot
    7. LG V20 Volume Button Replacement: step 8, image 1 of 2 LG V20 Volume Button Replacement: step 8, image 2 of 2
      • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
      Ask FixBot
    8. LG V20 Volume Button Replacement: step 9, image 1 of 1
      • Remove the motherboard cover.
      Ask FixBot
    1. LG V20 Volume Button Replacement, Volume Button: step 10, image 1 of 2 LG V20 Volume Button Replacement, Volume Button: step 10, image 2 of 2
      • Use the flat end of a spudger to slide the volume button out of its bracket and remove it.
      Ask FixBot
7 other people completed this guide.
Author
with
Garrett Janney
909 Reputation
4 Guides authored
Cal Poly, Team S22-G5, Livingston Spring 2017 Member of Cal Poly, Team S22-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G5
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 105
All Time: 4,069
