Up to 20% off select tools
LG V10 Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
108
All Time:
4,028
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 25 seconds
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Before replacing the battery, turn off the LG V10. If your LG V10 is being charged for a couple hours but quickly drains even when it’s not being used, for example the battery percentage goes from 100% to 95% within ten minutes of being unplugged, then the battery’s life has been depleted and may need to be replaced.
    1. LG V10 Battery Replacement, Battery: step 1, image 1 of 1
      • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
      • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
      • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
      Ask FixBot
    2. LG V10 Battery Replacement: step 2, image 1 of 2 LG V10 Battery Replacement: step 2, image 2 of 2
      • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
      Ask FixBot
After replacing the old battery with a new one, reattach the back cover and press down on all sides to make sure it's properly reattached.
3 other people completed this guide.
Author
with
Nikolai Lesh
344 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 108
All Time: 4,028
