Up to 20% off select tools
LG Ultimate 2 SD Card Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
54
All Time:
717
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to remove the SD card on your LG Ultimate 2. In order to remove the SD card, you will need to use a spudger in order to loosen the back of the phone. Then, you will remove the back of the phone with your hands. Finally, you will use your hand or a metal spudger to pull the SD card out of the phone.
    1. LG Ultimate 2 SD Card Replacement, SD Card: step 1, image 1 of 1
      • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
      Ask FixBot
    2. LG Ultimate 2 SD Card Replacement: step 2, image 1 of 1
      • Use your hand to pull the plastic cover completely off of the phone.
      Ask FixBot
    3. LG Ultimate 2 SD Card Replacement: step 3, image 1 of 1
      • Use the metal spudger or your hand to pull the SD card out.
      Ask FixBot
Author
with
Devin Isenhower
329 Reputation
2 Guides authored
IUPUI, Team S5-G2, Baechle Spring 2018 Member of IUPUI, Team S5-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 54
All Time: 717
