Up to 20% off select tools
LG Ultimate 2 Digitizer Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
66
All Time:
955
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, you will learn how to replace the digitizer on your LG Ultimate 2. This is going to require you to use a plastic spudger to loosen the screen, your hands to pull the screen off, and a screwdriver to unscrew the screen from the rest of the phone. You need to be careful when removing the screen as it is attached to a data cable that could sustain damage.
    1. LG Ultimate 2 Digitizer Replacement, Battery: step 1, image 1 of 1
      • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
      Ask FixBot
    2. LG Ultimate 2 Digitizer Replacement: step 2, image 1 of 1
      • Use your hand to pull the plastic cover completely off of the phone.
      Ask FixBot
    3. LG Ultimate 2 Digitizer Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the wedge near the bottom of the battery.
      • Lift the battery out.
      Ask FixBot
    1. LG Ultimate 2 Digitizer Replacement, Digitizer: step 4, image 1 of 2 LG Ultimate 2 Digitizer Replacement, Digitizer: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
      Ask FixBot
    2. LG Ultimate 2 Digitizer Replacement: step 5, image 1 of 2 LG Ultimate 2 Digitizer Replacement: step 5, image 2 of 2
      • Insert the plastic opening tool to start wedging the phone apart.
      • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
      Ask FixBot
    3. LG Ultimate 2 Digitizer Replacement: step 6, image 1 of 1
      • Use a plastic opening tool or fingernail to separate the zip connector.
      • The zip connector does not detach completely from the phone, but acts as a flap.
      Ask FixBot
    4. LG Ultimate 2 Digitizer Replacement: step 7, image 1 of 1
      • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
      Ask FixBot
    5. LG Ultimate 2 Digitizer Replacement: step 8, image 1 of 1
      • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
      • A hair dryer might be useful to help melt the adhesive.
      Ask FixBot
    6. LG Ultimate 2 Digitizer Replacement: step 9, image 1 of 1
      • Pry the screen off after all pieces have been loosened from the adhesive.
      Ask FixBot
Author
with
Devin Isenhower
329 Reputation
2 Guides authored
IUPUI, Team S5-G2, Baechle Spring 2018 Member of IUPUI, Team S5-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 66
All Time: 955
