LG UD501KOJ5 Dehumidifier Sensor Replacement
    1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: step 1, image 1 of 2 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: step 1, image 2 of 2
      • Unplug the dehumidifier then put on work gloves to protect your hands.
      • Remove the water collection bucket and set it aside.
      • Remove the air filter from the bottom of the front grille.
      Ask FixBot
    2. LG UD501KOJ5 Dehumidifier Sensor Replacement: step 2, image 1 of 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 2, image 2 of 2
      • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
      • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
      • The control board wire harness is still attached to the back of the front grille.
      Ask FixBot
    3. LG UD501KOJ5 Dehumidifier Sensor Replacement: step 3, image 1 of 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 3, image 2 of 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 3, image 3 of 3
      • Remove the screws that secure the back panel to the dehumidifier.
      • Carefully remove the back panel from the dehumidifier.
      • Remove the screws at the side.
      Ask FixBot
    4. LG UD501KOJ5 Dehumidifier Sensor Replacement: step 4, image 1 of 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 4, image 2 of 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 4, image 3 of 3
      • Remove the screws located at both sides of the back panel.
      • Remove the screws on the top left and top right which are connected to the control box.
      • Carefully remove the outer case.
      Ask FixBot
    5. LG UD501KOJ5 Dehumidifier Sensor Replacement: step 5, image 1 of 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 5, image 2 of 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 5, image 3 of 3
      • Disconnect the sensor wire harness from the electronic control board.
      • Disconnect the wire harness from the collection bucket float switch.
      • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
      Ask FixBot
    6. LG UD501KOJ5 Dehumidifier Sensor Replacement: step 6, image 1 of 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: step 6, image 2 of 2
      • Remove the humidity sensor from the evaporator fins.
      • Pull the sensor assembly out of the dehumidifier.
      • Remove any dust build-up with a dry cloth.
      • Push the new humidity sensor in place on the front of the evaporator fins.
      Ask FixBot
Gabrielle Campbell
133 Reputation
1 Guide authored
1 Guide Comment
I think the model number may be wrong.
https://www.lg.com/us/support/product/lg...
Hugh McNally - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 98
All Time: 3,551
