Up to 20% off select tools
LG TrueSteam Power Cord Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
8
Past 7 Days:
33
Past 30 Days:
115
All Time:
4,655
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
To replace the dryer cord for the LG TrueSteam you will simply need a Phillips #0 screwdriver. It will fit all screws that you will be taking out today. If not done correctly there could be some electrical hazards. Make sure to pull out the dryer from the wall to ensure maximum space for you to work with. Insure that you have plenty of light, and steady hands to complete this fix. The total list of Phillips head screws are: (2.2mm)x3, (3.2mm)x2, (6mm)x 2.
    1. LG TrueSteam  Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • To replace the dryer cord for the LG PureSteam you will simply need a #0 Phillips screwdriver. If not done correctly there could be some electrical hazards. Make sure to pull out the dryer from the wall to ensure maximum space for you to work with. Insure that you plenty of light, and steady hands to complete this fix.
      Ask FixBot
    2. LG TrueSteam  Power Cord Replacement: step 2, image 1 of 1
      • Turn off the power to your dryer by using the circuit breaker. This insures that there is absolutely no power being sent to the dryer outlet, creating the safest possible environment.
      Ask FixBot
    3. LG TrueSteam  Power Cord Replacement: step 3, image 1 of 2 LG TrueSteam  Power Cord Replacement: step 3, image 2 of 2
      • Use your Phillips #0 screwdriver to remove the back panel concealing the wires. It is located directly above where the power cable feeds into. It is held in place with one 3.2 mm screw. Once you remove that screw it should unhook from the slots that they are latched onto.
      Ask FixBot
    4. LG TrueSteam  Power Cord Replacement: step 4, image 1 of 1
      • Use the Phillips #0 to loosen the two 6mm screws that secure the clamps holding the wires in place. Simply loosening them and maneuvering them out of the hole will suffice.
      Ask FixBot
    5. LG TrueSteam  Power Cord Replacement: step 5, image 1 of 3 LG TrueSteam  Power Cord Replacement: step 5, image 2 of 3 LG TrueSteam  Power Cord Replacement: step 5, image 3 of 3
      • Remove the wires connected to the dryer with your Phillips #0 screwdriver, making sure to stay in control of the 2.2mm screws holding them in place.
      • Accidentally dropping them into the dryer will ensure you never see them again.
      Ask FixBot
    6. LG TrueSteam  Power Cord Replacement: step 6, image 1 of 3 LG TrueSteam  Power Cord Replacement: step 6, image 2 of 3 LG TrueSteam  Power Cord Replacement: step 6, image 3 of 3
      • Use the Phillips #0 to remove the green grounding wire held in place with a 3.2mm screw, and carefully remove the power cord from the dryer by pulling it out from the base of the feeding hole.
      Ask FixBot
    7. LG TrueSteam  Power Cord Replacement: step 7, image 1 of 2 LG TrueSteam  Power Cord Replacement: step 7, image 2 of 2
      • Notice that the grounding wire screw is a 3.2 mm screw compared to the other ones at 2.2mm. It is important to keep them separated. In the event that you lose a 2.2mm screw, there should be a spare screwed into the back of your dryer.
      Ask FixBot
    8. LG TrueSteam  Power Cord Replacement: step 8, image 1 of 3 LG TrueSteam  Power Cord Replacement: step 8, image 2 of 3 LG TrueSteam  Power Cord Replacement: step 8, image 3 of 3
      • Feed the new power cable into the wire hole, and screw the cables in from reverse order using the proper corresponding screws. Note that the white cables are stacked on top of each other. In that case the wire coming from the dryer goes under the wire from the new cord.
      Ask FixBot
    9. LG TrueSteam  Power Cord Replacement: step 9, image 1 of 2 LG TrueSteam  Power Cord Replacement: step 9, image 2 of 2
      • Lastly replace the back panel, and wire clamp. Ensure that the wire clamp hooks into the wire hole. This will keep the wires from falling out and getting damaged.
      Ask FixBot
Author
with
Miguel Rocha
243 Reputation
1 Guide authored
UW Tacoma, Team S1-G11, Cardinal Summer 2020 Member of UW Tacoma, Team S1-G11, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G11
1 Member
12 Guides authored
2 Guide Comments
The spare screw note was a life saver. Didn't even notice that was there and was scrambling to find a replacement before I found this guide.
Joey Cribbin - Reply Share
I have an existing manufacturer power cord that has no color coded wires. They’re all gray and homogenous. Can’t distinguish one from the other. What do I do? I uninstalled this cord thinking that I needed to replace it with a different cord but found out that it would actually work so I reinstalled it not knowing that it required a specific color code installation.
ascencion castaneda - Reply Share
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 115
All Time: 4,655
