Up to 20% off select tools
LG Tribute Touchscreen Replacement
Views: 17K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
104
All Time:
16,915
Comments: 4
4 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will assist in successfully replacing the LG Tribute touchscreen.
    1. LG Tribute Touchscreen Replacement, Battery: step 1, image 1 of 2 LG Tribute Touchscreen Replacement, Battery: step 1, image 2 of 2
      • Use the plastic opening tool to pry off the back cover.
      Ask FixBot
    2. LG Tribute Touchscreen Replacement: step 2, image 1 of 1
      • Lift the battery out of place.
      • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
      Ask FixBot
    1. LG Tribute Touchscreen Replacement, Mid-panel: step 3, image 1 of 2 LG Tribute Touchscreen Replacement, Mid-panel: step 3, image 2 of 2
      • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
      Ask FixBot
    2. LG Tribute Touchscreen Replacement: step 4, image 1 of 2 LG Tribute Touchscreen Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to loosen the tabs around the edge of the phone.
      • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
      • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
      Ask FixBot
    1. LG Tribute Touchscreen Replacement, Motherboard: step 5, image 1 of 1
      • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
      • The motherboard will be completely free from the front panel after this step.
      Ask FixBot
    1. LG Tribute Touchscreen Replacement, Touchscreen: step 6, image 1 of 3 LG Tribute Touchscreen Replacement, Touchscreen: step 6, image 2 of 3 LG Tribute Touchscreen Replacement, Touchscreen: step 6, image 3 of 3
      • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
      • When the frame is completely free, remove all of the glue.
      • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
      Ask FixBot
12 other people completed this guide.
Author
with
Aaron Amdall
940 Reputation
4 Guides authored
4 Guide Comments
thank you for all ypu work at web site
salah dholman - Reply Share
Can you peel away lens without taking apart ?
mikeknapik1 - Reply Share
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Reply Share
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 104
All Time: 16,915
