LG Tribute Rear-Facing Camera Replacement
    1. LG Tribute Rear-Facing Camera Replacement, Battery: step 1, image 1 of 2 LG Tribute Rear-Facing Camera Replacement, Battery: step 1, image 2 of 2
      • Use the plastic opening tool to pry off the back cover.
      Ask FixBot
    2. LG Tribute Rear-Facing Camera Replacement: step 2, image 1 of 1
      • Lift the battery out of place.
      • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
      Ask FixBot
    1. LG Tribute Rear-Facing Camera Replacement, Mid-panel: step 3, image 1 of 2 LG Tribute Rear-Facing Camera Replacement, Mid-panel: step 3, image 2 of 2
      • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
      Ask FixBot
    2. LG Tribute Rear-Facing Camera Replacement: step 4, image 1 of 2 LG Tribute Rear-Facing Camera Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to loosen the tabs around the edge of the phone.
      • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
      • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
      Ask FixBot
    1. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: step 5, image 1 of 2 LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: step 5, image 2 of 2
      • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
      • Lift the rear facing camera out of its housing.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 103
All Time: 1,054
