Up to 20% off select tools
LG Tribute HD Rear Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
63
All Time:
896
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to properly repair or replace the rear camera in the LG Tribute HD LS676. The rear camera may need cleaning if the lens has been damaged by water, dirt or sand. There may also be connectivity issues to the motherboard which will require disconnecting and reconnecting the ribbon cable from the camera to the motherboard. However, if the rear lens is broken or damaged causing the camera not to turn on, then is has to be replaced.
    1. LG Tribute HD Rear Camera  Replacement, Battery and SD Card: step 1, image 1 of 2 LG Tribute HD Rear Camera  Replacement, Battery and SD Card: step 1, image 2 of 2
      • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
      Ask FixBot
    2. LG Tribute HD Rear Camera  Replacement: step 2, image 1 of 2 LG Tribute HD Rear Camera  Replacement: step 2, image 2 of 2
      • Pull the battery out of the phone.
      • Remove the SD Card by sliding the card out as shown.
      Ask FixBot
    1. LG Tribute HD Rear Camera  Replacement, Rear Camera: step 3, image 1 of 2 LG Tribute HD Rear Camera  Replacement, Rear Camera: step 3, image 2 of 2
      • Remove the twelve 2mm JIS #00 screws from the mid-frame.
      Ask FixBot
    2. LG Tribute HD Rear Camera  Replacement: step 4, image 1 of 3 LG Tribute HD Rear Camera  Replacement: step 4, image 2 of 3 LG Tribute HD Rear Camera  Replacement: step 4, image 3 of 3
      • Using a plastic opening tool, remove the antenna extender from the mid-frame.
      Ask FixBot
    3. LG Tribute HD Rear Camera  Replacement: step 5, image 1 of 2 LG Tribute HD Rear Camera  Replacement: step 5, image 2 of 2
      • Using your fingers, remove the mid-frame.
      Ask FixBot
    4. LG Tribute HD Rear Camera  Replacement: step 6, image 1 of 2 LG Tribute HD Rear Camera  Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to disconnect the rear camera and pull from the phone.
      Ask FixBot
Author
with
Aalia Mohammed
454 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2018 Member of USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 63
All Time: 896
