LG Tribute HD Motherboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
72
All Time:
1,544
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach you how to properly replace the motherboard in the LG Tribute HD LS676. The motherboard is a key component that connects and controls all the other phone components. Caution should be taken when replacing it since it is a delicate component that can be easily damaged. Replacement of the motherboard will result in loss of old data and documents previously stored on the phone. It is recommended to externally back-up any important data from the phone before proceeding to replace the motherboard.
Tools
    1. LG Tribute HD Motherboard Replacement, Battery and SD Card: step 1, image 1 of 2 LG Tribute HD Motherboard Replacement, Battery and SD Card: step 1, image 2 of 2
      • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
      Ask FixBot
    2. LG Tribute HD Motherboard Replacement: step 2, image 1 of 2 LG Tribute HD Motherboard Replacement: step 2, image 2 of 2
      • Pull the battery out of the phone.
      • Remove the SD Card by sliding the card out as shown.
      Ask FixBot
    1. LG Tribute HD Motherboard Replacement, Motherboard: step 3, image 1 of 2 LG Tribute HD Motherboard Replacement, Motherboard: step 3, image 2 of 2
      • Remove the twelve 2mm JIS #00 screws from the mid-frame.
      Ask FixBot
    2. LG Tribute HD Motherboard Replacement: step 4, image 1 of 3 LG Tribute HD Motherboard Replacement: step 4, image 2 of 3 LG Tribute HD Motherboard Replacement: step 4, image 3 of 3
      • Using a plastic opening tool, remove the antenna extender from the mid-frame.
      Ask FixBot
    3. LG Tribute HD Motherboard Replacement: step 5, image 1 of 2 LG Tribute HD Motherboard Replacement: step 5, image 2 of 2
      • Using your fingers, remove the mid-frame.
      Ask FixBot
    4. LG Tribute HD Motherboard Replacement: step 6, image 1 of 3 LG Tribute HD Motherboard Replacement: step 6, image 2 of 3 LG Tribute HD Motherboard Replacement: step 6, image 3 of 3
      • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard and pull out to remove.
      Ask FixBot
    5. LG Tribute HD Motherboard Replacement: step 7, image 1 of 3 LG Tribute HD Motherboard Replacement: step 7, image 2 of 3 LG Tribute HD Motherboard Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, pry up the front facing speaker and remove from the phone.
      Ask FixBot
    6. LG Tribute HD Motherboard Replacement: step 8, image 1 of 1
      • Disconnect the display from the motherboard.
      Ask FixBot
    7. LG Tribute HD Motherboard Replacement: step 9, image 1 of 2 LG Tribute HD Motherboard Replacement: step 9, image 2 of 2
      • Use a plastic opening tool to pry up the motherboard and pull out to remove.
      Ask FixBot
2 other people completed this guide.
Aalia Mohammed
454 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2018 Member of USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Members
120 Guides authored
1 Guide Comment
svp ou peut-on trouver cette carte mère
Mourasilva Silva - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 72
All Time: 1,544
