LG Tribute HD Headphone Jack Replacement
  1. LG Tribute HD Headphone Jack Replacement, Battery and SD Card: step 1, image 1 of 2 LG Tribute HD Headphone Jack Replacement, Battery and SD Card: step 1, image 2 of 2
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. LG Tribute HD Headphone Jack Replacement: step 2, image 1 of 2 LG Tribute HD Headphone Jack Replacement: step 2, image 2 of 2
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. LG Tribute HD Headphone Jack Replacement, Headphone Jack: step 3, image 1 of 2 LG Tribute HD Headphone Jack Replacement, Headphone Jack: step 3, image 2 of 2
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute HD Headphone Jack Replacement: step 4, image 1 of 3 LG Tribute HD Headphone Jack Replacement: step 4, image 2 of 3 LG Tribute HD Headphone Jack Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  5. LG Tribute HD Headphone Jack Replacement: step 5, image 1 of 2 LG Tribute HD Headphone Jack Replacement: step 5, image 2 of 2
    • Using your fingers, remove the mid-frame.
  6. LG Tribute HD Headphone Jack Replacement: step 6, image 1 of 3 LG Tribute HD Headphone Jack Replacement: step 6, image 2 of 3 LG Tribute HD Headphone Jack Replacement: step 6, image 3 of 3
    • Use plastic opening tool to pry up the flex cable from the back panel.
    • Flip over and push on the back side of the headphone jack to dislodge it.
Jerry Koenig
715 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2018 Member of USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 79
All Time: 839
