LG Tribute HD Flex Cable Replacement
    1. LG Tribute HD Flex Cable Replacement, Battery and SD Card: step 1, image 1 of 2 LG Tribute HD Flex Cable Replacement, Battery and SD Card: step 1, image 2 of 2
      • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
      Ask FixBot
    2. LG Tribute HD Flex Cable Replacement: step 2, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 2, image 2 of 2
      • Pull the battery out of the phone.
      • Remove the SD Card by sliding the card out as shown.
      Ask FixBot
    1. LG Tribute HD Flex Cable Replacement, Flex Cable: step 3, image 1 of 2 LG Tribute HD Flex Cable Replacement, Flex Cable: step 3, image 2 of 2
      • Remove the twelve 2mm JIS #00 screws from the mid-frame.
      Ask FixBot
    2. LG Tribute HD Flex Cable Replacement: step 4, image 1 of 3 LG Tribute HD Flex Cable Replacement: step 4, image 2 of 3 LG Tribute HD Flex Cable Replacement: step 4, image 3 of 3
      • Using a plastic opening tool, remove the antenna extender from the bottom.
      Ask FixBot
    3. LG Tribute HD Flex Cable Replacement: step 5, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 5, image 2 of 2
      • Using your fingers, remove the mid-frame.
      Ask FixBot
    4. LG Tribute HD Flex Cable Replacement: step 6, image 1 of 3 LG Tribute HD Flex Cable Replacement: step 6, image 2 of 3 LG Tribute HD Flex Cable Replacement: step 6, image 3 of 3
      • Use a plastic opening tool to disconnect the front and rear cameras from the motherboard.
      • Remove the cameras from the phone.
      Ask FixBot
    5. LG Tribute HD Flex Cable Replacement: step 7, image 1 of 3 LG Tribute HD Flex Cable Replacement: step 7, image 2 of 3 LG Tribute HD Flex Cable Replacement: step 7, image 3 of 3
      • Using a plastic opening tool, pry up the front facing speaker and remove it from the phone.
      Ask FixBot
    6. LG Tribute HD Flex Cable Replacement: step 8, image 1 of 1
      • Disconnect the LCD from the motherboard with a plastic opening tool.
      Ask FixBot
    7. LG Tribute HD Flex Cable Replacement: step 9, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 9, image 2 of 2
      • Use a plastic opening tool to pry up the motherboard form the display housing.
      • Remove the motherboard from the phone.
      Ask FixBot
    8. LG Tribute HD Flex Cable Replacement: step 10, image 1 of 2 LG Tribute HD Flex Cable Replacement: step 10, image 2 of 2
      • Use your fingers to remove the flex cables from the phone.
      Ask FixBot
Dhruv Patel
273 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2018 Member of USF Tampa, Team S1-G3, Nance Spring 2018
USFT-NANCE-S18S1G3
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 81
All Time: 1,067
