LG Tribute 5 Motherboard Replacement
    1. LG Tribute 5 Motherboard Replacement, Battery: step 1, image 1 of 2 LG Tribute 5 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
      Ask FixBot
    2. LG Tribute 5 Motherboard Replacement: step 2, image 1 of 3 LG Tribute 5 Motherboard Replacement: step 2, image 2 of 3 LG Tribute 5 Motherboard Replacement: step 2, image 3 of 3
      • Gently lift the battery out from the compartment.
      • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
      Ask FixBot
    1. LG Tribute 5 Motherboard Replacement, Motherboard: step 3, image 1 of 3 LG Tribute 5 Motherboard Replacement, Motherboard: step 3, image 2 of 3 LG Tribute 5 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Remove the nine 2mm JIS #00 screws from the mid-frame.
      Ask FixBot
    2. LG Tribute 5 Motherboard Replacement: step 4, image 1 of 3 LG Tribute 5 Motherboard Replacement: step 4, image 2 of 3 LG Tribute 5 Motherboard Replacement: step 4, image 3 of 3
      • Using an iFixit opening tool, remove the antenna extender located at the bottom.
      Ask FixBot
    3. LG Tribute 5 Motherboard Replacement: step 5, image 1 of 2 LG Tribute 5 Motherboard Replacement: step 5, image 2 of 2
      • Gently remove the mid-frame using an iFixit opening tool as shown.
      • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
      Ask FixBot
    4. LG Tribute 5 Motherboard Replacement: step 6, image 1 of 2 LG Tribute 5 Motherboard Replacement: step 6, image 2 of 2
      • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
      • Remove the front facing camera from the top right corner of the motherboard.
      Ask FixBot
    5. LG Tribute 5 Motherboard Replacement: step 7, image 1 of 1
      • Gently pull the speaker out from its compartment with the iFixit opening tool.
      Ask FixBot
    6. LG Tribute 5 Motherboard Replacement: step 8, image 1 of 1
      • Disconnect the flex cable from the motherboard with the iFixit opening tool.
      Ask FixBot
    7. LG Tribute 5 Motherboard Replacement: step 9, image 1 of 1
      • Gently pull up and remove the motherboard using the iFixit opening tool.
      Ask FixBot
4 other people completed this guide.
Renee Dawn Nelson
472 Reputation
3 Guides authored
UW Tacoma, Team S1-G6, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G6, Cardinal Spring 2019
UWT-CARDINAL-S19S1G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 719
