Up to 20% off select tools
LG Treasure Display Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
61
All Time:
2,039
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
This guide will remove the digitizer and mother board from the display screen, allowing it to be replaced.
    1. LG Treasure Display Replacement, Battery: step 1, image 1 of 2 LG Treasure Display Replacement, Battery: step 1, image 2 of 2
      • Make sure the LG Treasure is turned off.
      • Pull off the back cover from the phone using the groove on the bottom right side.
      Ask FixBot
    2. LG Treasure Display Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by lifting up on the bottom end of the battery.
      Ask FixBot
    1. LG Treasure Display Replacement, Display: step 3, image 1 of 2 LG Treasure Display Replacement, Display: step 3, image 2 of 2
      • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
      • Work your way around the edge of the phone, gently prying the digitizer off the phone.
      Ask FixBot
    2. LG Treasure Display Replacement: step 4, image 1 of 3 LG Treasure Display Replacement: step 4, image 2 of 3 LG Treasure Display Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the Front Facing Camera, Rear Facing Camera, and the Display Connector by lifting the gold film-like connectors out of their connections.
      • Remove the ear speaker and audio jack by lifting them out of place using the tweezers.
      Ask FixBot
    3. LG Treasure Display Replacement: step 5, image 1 of 2 LG Treasure Display Replacement: step 5, image 2 of 2
      • Remove the motherboard from the display screen by lifting it out of place.
      Ask FixBot
5 other people completed this guide.
Author
with
david amirahmadi
594 Reputation
5 Guides authored
UW Stout, Team S8-G5, Ogden Spring 2018 Member of UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 61
All Time: 2,039
