Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
Using a Philips #00 screwdriver, remove the hidden screws from both sides.
Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
2 other people completed this guide.
