LG Stylo 3 Plus Headphone Jack Replacement
    1. LG Stylo 3 Plus Headphone Jack Replacement, Back Cover: step 1, image 1 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Back Cover: step 1, image 2 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Back Cover: step 1, image 3 of 3
      • Power off the phone before beginning disassembly.
      • Place the phone face down.
      • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
      • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
      Ask FixBot
    1. LG Stylo 3 Plus Headphone Jack Replacement, Battery: step 2, image 1 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Battery: step 2, image 2 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Battery: step 2, image 3 of 3
      • Place the back cover off to the side.
      • Insert the opening tool into the small gap below the battery.
      • Carefully pop the battery out to prevent damage.
      Ask FixBot
    1. LG Stylo 3 Plus Headphone Jack Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Rear Camera: step 3, image 3 of 3
      • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
      • Use the plastic opening tool to remove the inner case.
      • Carefully remove the inner case.
      Ask FixBot
    2. LG Stylo 3 Plus Headphone Jack Replacement: step 4, image 1 of 2 LG Stylo 3 Plus Headphone Jack Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use your fingernail or the plastic opening tool to flip the flex cable.
      • Use the precision tweezers to carefully grasp and pull out the camera.
      Ask FixBot
    1. LG Stylo 3 Plus Headphone Jack Replacement, Front Camera: step 5, image 1 of 2 LG Stylo 3 Plus Headphone Jack Replacement, Front Camera: step 5, image 2 of 2
      Buy
      • Carefully flip open the flex cable box with the plastic opening tool.
      • Using precision tweezers, carefully lift the front camera off the device.
      Ask FixBot
    1. LG Stylo 3 Plus Headphone Jack Replacement, Motherboard: step 6, image 1 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Motherboard: step 6, image 2 of 3 LG Stylo 3 Plus Headphone Jack Replacement, Motherboard: step 6, image 3 of 3
      • Gently flip open the flex cable box using a blue plastic opening tool.
      • Carefully remove the motherboard with your hands or a blue plastic opening tool.
      • Make sure all parts are secure while taking out motherboard.
      Ask FixBot
    1. LG Stylo 3 Plus Headphone Jack Replacement, Headphone Jack: step 7, image 1 of 2 LG Stylo 3 Plus Headphone Jack Replacement, Headphone Jack: step 7, image 2 of 2
      • Remove the headphone jack.
      Ask FixBot
Justin Ogihara
31,440 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 771
