Up to 20% off select tools
LG Stylo 2 Rear Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
51
All Time:
974
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
For this removal you will need a PH00 screw driver to remove the necessary screws. It is recommended to have very clean hands or even to wear gloves as you will be interacting with the motherboard of the phone.
    1. LG Stylo 2 Rear Camera Replacement, Battery: step 1, image 1 of 3 LG Stylo 2 Rear Camera Replacement, Battery: step 1, image 2 of 3 LG Stylo 2 Rear Camera Replacement, Battery: step 1, image 3 of 3
      • First you need to remove the back case of the phone.
      • Place the phone face down.
      • Using the plastic opening tool, insert into the initial gap shown.
      • Slowly guide the tool around the case until the case comes off with ease.
      Ask FixBot
    2. LG Stylo 2 Rear Camera Replacement: step 2, image 1 of 3 LG Stylo 2 Rear Camera Replacement: step 2, image 2 of 3 LG Stylo 2 Rear Camera Replacement: step 2, image 3 of 3
      • Place the back case to the side.
      • Use your finger or the opening tool to remove battery.
      • Remove the battery carefully to not damage the phone or the battery.
      Ask FixBot
    1. LG Stylo 2 Rear Camera Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 2 Rear Camera Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 2 Rear Camera Replacement, Rear Camera: step 3, image 3 of 3
      • Remove the eleven 4mm Phillips #00 screws.
      • Place screws in safe location.
      • Use Plastic opener tool to remove inner case.
      • Gently remove inner case.
      Ask FixBot
    2. LG Stylo 2 Rear Camera Replacement: step 4, image 1 of 3 LG Stylo 2 Rear Camera Replacement: step 4, image 2 of 3 LG Stylo 2 Rear Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use your finger or the opener to flip the flex cable shown in red box.
      • Use the precision tweezers to remove camera carefully.
      Ask FixBot
Author
with
Devon Barber
994 Reputation
5 Guides authored
USF Tampa, Team S11-G1, Cheng Spring 2018 Member of USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 51
All Time: 974
