Up to 20% off select tools
LG Stylo 2 Motherboard Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
63
All Time:
2,970
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
When your phone becomes water damaged or any other internal damage comes to the motherboard it will become necessary to replace it. This guide will show you exactly how to do so with ease. When touching internal components make sure your hands are very clean or you are wearing gloves.
    1. LG Stylo 2 Motherboard  Replacement, Battery: step 1, image 1 of 3 LG Stylo 2 Motherboard  Replacement, Battery: step 1, image 2 of 3 LG Stylo 2 Motherboard  Replacement, Battery: step 1, image 3 of 3
      • First you need to remove the back case of the phone.
      • Place the phone face down.
      • Using the plastic opening tool, insert into the initial gap shown.
      • Slowly guide the tool around the case until the case comes off with ease.
      Ask FixBot
    2. LG Stylo 2 Motherboard  Replacement: step 2, image 1 of 3 LG Stylo 2 Motherboard  Replacement: step 2, image 2 of 3 LG Stylo 2 Motherboard  Replacement: step 2, image 3 of 3
      • Place the back case to the side.
      • Use your finger or the opening tool to remove battery.
      • Remove the battery carefully to not damage the phone or the battery.
      Ask FixBot
    1. LG Stylo 2 Motherboard  Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 2 Motherboard  Replacement, Rear Camera: step 3, image 3 of 3
      • Remove the eleven 4mm Phillips #00 screws.
      • Place screws in safe location.
      • Use Plastic opener tool to remove inner case.
      • Gently remove inner case.
      Ask FixBot
    2. LG Stylo 2 Motherboard  Replacement: step 4, image 1 of 3 LG Stylo 2 Motherboard  Replacement: step 4, image 2 of 3 LG Stylo 2 Motherboard  Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use your finger or the opener to flip the flex cable shown in red box.
      • Use the precision tweezers to remove camera carefully.
      Ask FixBot
    1. LG Stylo 2 Motherboard  Replacement, Motherboard: step 5, image 1 of 3 LG Stylo 2 Motherboard  Replacement, Motherboard: step 5, image 2 of 3 LG Stylo 2 Motherboard  Replacement, Motherboard: step 5, image 3 of 3
      • Gently flip the cables(shown in red boxes) using the opener tool.
      • Gently remove the motherboard itself.
      • Place motherboard on a soft surface to not damage it.
      Ask FixBot
Author
with
Devon Barber
994 Reputation
5 Guides authored
USF Tampa, Team S11-G1, Cheng Spring 2018 Member of USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Members
60 Guides authored
1 Guide Comment
Charging retain 2.1
Kashif Kashi - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 63
All Time: 2,970
