Up to 20% off select tools
LG Stylo 2 Display Replacement
Views: 6.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
61
All Time:
6,781
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the display on the phone is cracked or is unresponsive to touch in areas or the whole phone you may need to replace the display. This will require you to take everything out of the phone as the display itself cannot be removed solely without possible damage to other parts of the phone.
    1. LG Stylo 2 Display Replacement, Battery: step 1, image 1 of 3 LG Stylo 2 Display Replacement, Battery: step 1, image 2 of 3 LG Stylo 2 Display Replacement, Battery: step 1, image 3 of 3
      • First you need to remove the back case of the phone.
      • Place the phone face down.
      • Using the plastic opening tool, insert into the initial gap shown.
      • Slowly guide the tool around the case until the case comes off with ease.
      Ask FixBot
    2. LG Stylo 2 Display Replacement: step 2, image 1 of 3 LG Stylo 2 Display Replacement: step 2, image 2 of 3 LG Stylo 2 Display Replacement: step 2, image 3 of 3
      • Place the back case to the side.
      • Use your finger or the opening tool to remove battery.
      • Remove the battery carefully to not damage the phone or the battery.
      Ask FixBot
    1. LG Stylo 2 Display Replacement, Rear Camera: step 3, image 1 of 3 LG Stylo 2 Display Replacement, Rear Camera: step 3, image 2 of 3 LG Stylo 2 Display Replacement, Rear Camera: step 3, image 3 of 3
      • Remove the eleven 4mm Phillips #00 screws.
      • Place screws in safe location.
      • Use Plastic opener tool to remove inner case.
      • Gently remove inner case.
      Ask FixBot
    2. LG Stylo 2 Display Replacement: step 4, image 1 of 3 LG Stylo 2 Display Replacement: step 4, image 2 of 3 LG Stylo 2 Display Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use your finger or the opener to flip the flex cable shown in red box.
      • Use the precision tweezers to remove camera carefully.
      Ask FixBot
    1. LG Stylo 2 Display Replacement, Motherboard: step 5, image 1 of 3 LG Stylo 2 Display Replacement, Motherboard: step 5, image 2 of 3 LG Stylo 2 Display Replacement, Motherboard: step 5, image 3 of 3
      • Gently flip the cables(shown in red boxes) using the opener tool.
      • Gently remove the motherboard itself.
      • Place motherboard on a soft surface to not damage it.
      Ask FixBot
    1. LG Stylo 2 Display Replacement, Display: step 6, image 1 of 3 LG Stylo 2 Display Replacement, Display: step 6, image 2 of 3 LG Stylo 2 Display Replacement, Display: step 6, image 3 of 3
      • Carefully remove the Vibrator.
      • Carefully remove the sensor.
      • Prepare to remove film.
      Ask FixBot
    2. LG Stylo 2 Display Replacement: step 7, image 1 of 3 LG Stylo 2 Display Replacement: step 7, image 2 of 3 LG Stylo 2 Display Replacement: step 7, image 3 of 3
      Buy
      • Use the tweezers to peel the film off carefully.
      • Use the tweezers to remove the headphone jack gently.
      • Place all three devices in a safe, known, location.
      Ask FixBot
15 other people completed this guide.
Author
with
Devon Barber
994 Reputation
5 Guides authored
USF Tampa, Team S11-G1, Cheng Spring 2018 Member of USF Tampa, Team S11-G1, Cheng Spring 2018
USFT-CHENG-S18S11G1
4 Members
60 Guides authored
2 Guide Comments
Hello guys
I just replaced the screen for my LG Stylus 2 plus. I got the display off https://www.injuredgadgets.com/lg-stylus...
But after replacing the screen and turning it on only the back light is functioning. I tried reusing the old display and it worked just fine. Is there any suggestions to why this one is not working or is my new screen just a bust ?
Several Genie - Reply Share
I've got the same problem please help this phone has all my late sons pictures and my daughter's it's a LG Stylo 2
Cody Pinson - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 61
All Time: 6,781
