Up to 20% off select tools
LG Spectrum Sim/SD Port Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
75
All Time:
701
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the phone is having internet issues or memory problems, replacing the SIM/SD Port could resolve these problems.
    1. LG Spectrum Sim/SD Port Replacement, Battery: step 1, image 1 of 2 LG Spectrum Sim/SD Port Replacement, Battery: step 1, image 2 of 2
      • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
      Ask FixBot
    2. LG Spectrum Sim/SD Port Replacement: step 2, image 1 of 1
      • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
      Ask FixBot
    1. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: step 3, image 1 of 2 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: step 3, image 2 of 2
      • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
      • Use the magnetic mat to keep the screws in one place.
      Ask FixBot
    2. LG Spectrum Sim/SD Port Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
      Ask FixBot
    3. LG Spectrum Sim/SD Port Replacement: step 5, image 1 of 1
      • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
      Ask FixBot
    4. LG Spectrum Sim/SD Port Replacement: step 6, image 1 of 1
      • Hook the plastic opening tool underneath the plate and gently lift it up.
      Ask FixBot
    5. LG Spectrum Sim/SD Port Replacement: step 7, image 1 of 1
      • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
      Ask FixBot
Author
with
Aiman Sallam
506 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Spring 2016 Member of USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 75
All Time: 701
