Up to 20% off select tools
LG Spectrum Motherboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
87
All Time:
1,261
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If you are having issues with your motherboard, such as the blue screen of death, constant errors, or crashes you may need to replace the motherboard. This guide will take you through the necessary steps to replace the Motherboard.
    1. LG Spectrum Motherboard Replacement, Battery: step 1, image 1 of 2 LG Spectrum Motherboard Replacement, Battery: step 1, image 2 of 2
      • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
      Ask FixBot
    2. LG Spectrum Motherboard Replacement: step 2, image 1 of 1
      • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
      Ask FixBot
    1. LG Spectrum Motherboard Replacement, Sim/SD Port: step 3, image 1 of 2 LG Spectrum Motherboard Replacement, Sim/SD Port: step 3, image 2 of 2
      • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
      • Use the magnetic mat to keep the screws in one place.
      Ask FixBot
    2. LG Spectrum Motherboard Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
      Ask FixBot
    3. LG Spectrum Motherboard Replacement: step 5, image 1 of 1
      • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
      Ask FixBot
    4. LG Spectrum Motherboard Replacement: step 6, image 1 of 1
      • Hook the plastic opening tool underneath the plate and gently lift it up.
      Ask FixBot
    5. LG Spectrum Motherboard Replacement: step 7, image 1 of 1
      • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
      Ask FixBot
    1. LG Spectrum Motherboard Replacement, Motherboard: step 8, image 1 of 2 LG Spectrum Motherboard Replacement, Motherboard: step 8, image 2 of 2
      • Use the plastic opening tool to lift up the connector that holds the camera to the board.
      Ask FixBot
    2. LG Spectrum Motherboard Replacement: step 9, image 1 of 1
      • Pull the camera gently out of its housing in the motherboard with your fingers.
      Ask FixBot
    3. LG Spectrum Motherboard Replacement: step 10, image 1 of 2 LG Spectrum Motherboard Replacement: step 10, image 2 of 2
      • Using the plastic opening tool, gently pry up the audio port connector.
      Ask FixBot
    4. LG Spectrum Motherboard Replacement: step 11, image 1 of 1
      • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
      Ask FixBot
    5. LG Spectrum Motherboard Replacement: step 12, image 1 of 2 LG Spectrum Motherboard Replacement: step 12, image 2 of 2
      • Detach the two cable connector wires from the motherboard with the plastic opening tool.
      • Detach the remaining five connectors from the phone with the plastic opening tool.
      Ask FixBot
    6. LG Spectrum Motherboard Replacement: step 13, image 1 of 2 LG Spectrum Motherboard Replacement: step 13, image 2 of 2
      • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
      Ask FixBot
Author
with
Aiman Sallam
506 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Spring 2016 Member of USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 87
All Time: 1,261
