Up to 20% off select tools
LG Spectrum Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
85
All Time:
703
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your camera continues to malfunction, such as taking blurry pictures, or if the camera lens is broken. This guide should show you how to easily replace your LG Spectrum Camera.
    1. LG Spectrum Camera Replacement, Battery: step 1, image 1 of 2 LG Spectrum Camera Replacement, Battery: step 1, image 2 of 2
      • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
      Ask FixBot
    2. LG Spectrum Camera Replacement: step 2, image 1 of 1
      • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
      Ask FixBot
    1. LG Spectrum Camera Replacement, Camera: step 3, image 1 of 2 LG Spectrum Camera Replacement, Camera: step 3, image 2 of 2
      • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
      • Use the magnet board to keep the screws in one place.
      Ask FixBot
    2. LG Spectrum Camera Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
      Ask FixBot
    3. LG Spectrum Camera Replacement: step 5, image 1 of 2 LG Spectrum Camera Replacement: step 5, image 2 of 2
      • Remove the camera by gently lifting the film that is attached to it from motherboard with the plastic opening tool.
      Ask FixBot
    4. LG Spectrum Camera Replacement: step 6, image 1 of 1
      • Use the plastic opening tool, or your hand, to pull up on the camera and remove it from the motherboard.
      Ask FixBot
Author
with
Aiman Sallam
506 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Spring 2016 Member of USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 85
All Time: 703
