Up to 20% off select tools
LG Risio Screen Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
58
All Time:
2,139
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. LG Risio Screen Replacement, Back Panel: step 1, image 1 of 2 LG Risio Screen Replacement, Back Panel: step 1, image 2 of 2
      • Use a plastic opening tool to seperate the back panel from the device.
      • Remove the back panel.
      Ask FixBot
    1. LG Risio Screen Replacement, Battery: step 2, image 1 of 1
      • Place your thumb along the bottom of the battery and pry upwards to remove.
      Ask FixBot
    1. LG Risio Screen Replacement, Midframe: step 3, image 1 of 1
      • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
      Ask FixBot
    2. LG Risio Screen Replacement: step 4, image 1 of 2 LG Risio Screen Replacement: step 4, image 2 of 2
      • Remove the eight Phillips #0 screws from the internal support frame.
      Ask FixBot
    3. LG Risio Screen Replacement: step 5, image 1 of 3 LG Risio Screen Replacement: step 5, image 2 of 3 LG Risio Screen Replacement: step 5, image 3 of 3
      • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
      Ask FixBot
    4. LG Risio Screen Replacement: step 6, image 1 of 1
      • Using your hand, pick up the midframe to separate it from the phone.
      Ask FixBot
    1. LG Risio Screen Replacement, Front-Facing Camera: step 7, image 1 of 2 LG Risio Screen Replacement, Front-Facing Camera: step 7, image 2 of 2
      • Unclip the front camera connector from the motherboard and lift it from the frame.
      Ask FixBot
    1. LG Risio Screen Replacement, Motherboard: step 8, image 1 of 2 LG Risio Screen Replacement, Motherboard: step 8, image 2 of 2
      • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
      • The screen connector is the part that has P5 written on it.
      Ask FixBot
    2. LG Risio Screen Replacement: step 9, image 1 of 1
      • On the side with the screen connector, pull the two tabs away from the device.
      • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
      Ask FixBot
    1. LG Risio Screen Replacement, Screen: step 10, image 1 of 2 LG Risio Screen Replacement, Screen: step 10, image 2 of 2
      • Using a hot air gun or hair dryer, heat the screen assembly, and pry it from the frame using your fingers (or an iFixit prying tool).
      Ask FixBot
2 other people completed this guide.
Author
with
John Breaux
196 Reputation
1 Guide authored
2 Guide Comments
Thank you John Breaux! Clear and precise instructions! Easy to follow! Like a US Army instruction manual. Big help fixing my homeless friend's phone! Now she can at least stay in touch and find better help! I thank you and little June says thank you and she will pray for your health and happiness.She is 208 days sober and grateful for every bit of help in her life.
ericinpotrero@yahoo.com - Reply Share
You're welcome! Congratulations to your friend for 208 days sober! I wish you both good health and happiness as well.
John Breaux - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 58
All Time: 2,139
