Up to 20% off select tools
LG Refrigerator Water Filter Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
168
All Time:
1,912
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 4 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the water filter on your LG refrigerator. This guide is for refrigerators that have the filter located in the rear of the fresh food area in the corner.
This guide will work for most LG refrigerators with the above arrangement. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
If your water filter is clogged, your water dispenser may have poor-tasting water and ice cubes, and the flow rate may be reduced. You should change your filter about every six months.
    1. LG Refrigerator Water Filter Replacement, Open the doors: step 1, image 1 of 3 LG Refrigerator Water Filter Replacement, Open the doors: step 1, image 2 of 3 LG Refrigerator Water Filter Replacement, Open the doors: step 1, image 3 of 3
      • Open both refrigerator doors fully.
      Ask FixBot
    1. LG Refrigerator Water Filter Replacement, Remove the shelves: step 2, image 1 of 3 LG Refrigerator Water Filter Replacement, Remove the shelves: step 2, image 2 of 3 LG Refrigerator Water Filter Replacement, Remove the shelves: step 2, image 3 of 3
      • Lift up the front edge of the shelf to release it.
      • Unhook the shelf and remove it.
      • Repeat the last two steps for each shelf you wish to remove.
      Ask FixBot
    1. LG Refrigerator Water Filter Replacement, Remove the water filter: step 3, image 1 of 3 LG Refrigerator Water Filter Replacement, Remove the water filter: step 3, image 2 of 3 LG Refrigerator Water Filter Replacement, Remove the water filter: step 3, image 3 of 3
      • The first photo shows a refrigerator with a water filter plug installed. If your refrigerator looks like this it does not yet have a water filter installed.
      • You may choose to shut off the water supply to the refrigerator before loosening the filter cartridge or plug. This provides extra protection against leakage while removing the filter.
      • To release your water filter, rotate it one-quarter turn counterclockwise.
      Ask FixBot
    2. LG Refrigerator Water Filter Replacement, Remove the water filter: step 4, image 1 of 1
      • Pull the filter down to remove it.
      Ask FixBot
    3. LG Refrigerator Water Filter Replacement, Prepare the replacement water filter: step 5, image 1 of 2 LG Refrigerator Water Filter Replacement, Prepare the replacement water filter: step 5, image 2 of 2
      • Your replacement filter may have a cap over the seals. Be sure to remove it before installing the new filter.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 168
All Time: 1,912
