LG Refrigerator Water Dispensing Switch Testing and Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
42
Past 30 Days:
146
All Time:
2,457
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to test and replace the water dispensing switch on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The water dispensing switch triggers a solenoid valve in the refrigerator so that it dispenses chilled water through the dispenser.
If the switch fails, the refrigerator will either not dispense water or won't stop dispensing water.
The repair is moderately difficult. The removal of the dispensing unit is probably the most challenging step.
Tools
    1. LG Refrigerator Water Dispensing Switch Testing and Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. LG Refrigerator Water Dispensing Switch Testing and Replacement, Loosen the left door handle set screws: step 2, image 1 of 2 LG Refrigerator Water Dispensing Switch Testing and Replacement, Loosen the left door handle set screws: step 2, image 2 of 2
      • To remove the left door handle, first open the right door.
      • Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
      Ask FixBot
    2. LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the left door handle: step 3, image 1 of 2 LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the left door handle: step 3, image 2 of 2
      • Pull the left door handle straight off to remove it.
      Ask FixBot
    1. LG Refrigerator Water Dispensing Switch Testing and Replacement, Retaining clip locations: step 4, image 1 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Retaining clip locations: step 4, image 2 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Retaining clip locations: step 4, image 3 of 3
      • The dispenser assembly is secured by very strong clips, making it very difficult to remove. Take note of the clip location examples shown in the photos:
      • Right side clips
      • Top clips
      • Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
      • During disassembly, you may break some of these clips. If you do, don't worry; the assembly does not need all the clips to be properly secured.
      Ask FixBot
    2. LG Refrigerator Water Dispensing Switch Testing and Replacement, Release the dispenser: step 5, image 1 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Release the dispenser: step 5, image 2 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Release the dispenser: step 5, image 3 of 3
      • Use a spudger to pry out the top edge of the dispenser assembly.
      • Once you've created a gap, use your fingertips to pull the edge downward.
      • Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
      • Optionally, you may use a flat-blade screwdriver to assist in this process. Be careful not to damage the door; you may scratch the door surface or dent the rim of the dispenser opening.
      Ask FixBot
    3. LG Refrigerator Water Dispensing Switch Testing and Replacement, Reposition the dispenser: step 6, image 1 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Reposition the dispenser: step 6, image 2 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Reposition the dispenser: step 6, image 3 of 3
      • Grasp the top edge of the dispenser assembly in the middle and pull outwards.
      • Continue prying and pulling around the perimeter of the assembly to release it.
      Ask FixBot
    4. LG Refrigerator Water Dispensing Switch Testing and Replacement: step 7, image 1 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement: step 7, image 2 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement: step 7, image 3 of 3
      • Grasp the assembly firmly and pull it out of the refrigerator door.
      • Don't try to pull the assembly completely off the refrigerator door. The assembly is still connected with numerous wires. These are mainly connected to the left side of the dispenser.
      Ask FixBot
    5. LG Refrigerator Water Dispensing Switch Testing and Replacement, Disconnect the dispenser: step 8, image 1 of 1
      • Squeeze the multiple wire connectors and pull them straight off to disconnect them from the various PC boards.
      • Some of the connectors may be permanently attached to the PC board and can't be removed.
      Ask FixBot
    6. LG Refrigerator Water Dispensing Switch Testing and Replacement: step 9, image 1 of 2 LG Refrigerator Water Dispensing Switch Testing and Replacement: step 9, image 2 of 2
      • Squeeze and separate the various connectors in the wiring harness. The photo shows two examples.
      Ask FixBot
    7. LG Refrigerator Water Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: step 10, image 1 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: step 10, image 2 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: step 10, image 3 of 3
      • Use a Phillips screwdriver to remove the screw securing the circuit board holder to the dispenser assembly. Many, but not all, units will have this PC board and holder.
      • Lift and remove the circuit board holder from the dispenser assembly.
      Ask FixBot
    8. LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the dispenser: step 11, image 1 of 1
      • You can now remove the dispenser from the refrigerator.
      • The circuit board holder, if present, can be suspended from the harness wires, as its weight is minimal.
      Ask FixBot
    1. LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the water dispensing switch bracket: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove screws securing the water switch bracket to the dispenser assembly.
      Ask FixBot
    2. LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the switch bracket: step 13, image 1 of 2 LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the switch bracket: step 13, image 2 of 2
      • Lift the switch bracket off the dispenser assembly.
      Ask FixBot
    3. LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the water dispensing switch from the bracket: step 14, image 1 of 2 LG Refrigerator Water Dispensing Switch Testing and Replacement, Remove the water dispensing switch from the bracket: step 14, image 2 of 2
      • Slide the water dispensing switch off of its pegs on the bracket.
      Ask FixBot
    4. LG Refrigerator Water Dispensing Switch Testing and Replacement, Disconnect the water dispensing switch: step 15, image 1 of 2 LG Refrigerator Water Dispensing Switch Testing and Replacement, Disconnect the water dispensing switch: step 15, image 2 of 2
      • Pull the connector straight off the water dispensing switch to disconnect it.
      Ask FixBot
    5. LG Refrigerator Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: step 16, image 1 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: step 16, image 2 of 3 LG Refrigerator Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: step 16, image 3 of 3
      • If you have a multimeter, you can test to see if your water dispensing switch is good or not. Set your multimeter to the continuity function, with beeper.
      • Touch one probe to each of the switch terminals at the same time.
      • When you operate the small lever on the switch the meter should sound.
      • When you release the small lever on the switch the meter should not sound.
      • If the switch does not operate as described above, replace it.
      Ask FixBot
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 146
All Time: 2,457
