LG Refrigerator Model LFX25973 Freezer Light Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
63
All Time:
378
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove the freezer light on your LG model LFX25973 refrigerator.
The freezer light allows you to see the contents of the freezer drawer more easily.
Tools
    1. LG Refrigerator Model LFX25973 Freezer Light Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser Fan Motor
      • Compressor Motor and Thermal Overload Device
      • Water Supply Valve Assembly
      Ask FixBot
    1. LG Refrigerator Model LFX25973 Freezer Light Replacement, Open the freezer door: step 2, image 1 of 2 LG Refrigerator Model LFX25973 Freezer Light Replacement, Open the freezer door: step 2, image 2 of 2
      • Pull open the freezer door fully.
      Ask FixBot
    2. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer and bin: step 3, image 1 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer and bin: step 3, image 2 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer and bin: step 3, image 3 of 3
      • Lift and remove the upper pull-out drawer.
      • Lift and remove the main drawer bin.
      Ask FixBot
    3. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer rail covers: step 4, image 1 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer rail covers: step 4, image 2 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer rail covers: step 4, image 3 of 3
      • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
      • Lift the cover off of the rail and remove it.
      • Repeat this procedure for the left drawer rail cover.
      Ask FixBot
    4. LG Refrigerator Model LFX25973 Freezer Light Replacement, Reassembly notes: step 5, image 1 of 2 LG Refrigerator Model LFX25973 Freezer Light Replacement, Reassembly notes: step 5, image 2 of 2
      • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
      • Hold the drawer rail cover flush against the side of the drawer rail.
      • You should feel the locking tabs protruding.
      • Push the rail cover straight downward to install. It should click into place.
      Ask FixBot
    5. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer: step 6, image 1 of 2 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the drawer: step 6, image 2 of 2
      • Use a Phillips screwdriver to remove the 10.4 mm‑long screw securing the drawer to each of the drawer slides.
      Ask FixBot
    6. LG Refrigerator Model LFX25973 Freezer Light Replacement: step 7, image 1 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement: step 7, image 2 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement: step 7, image 3 of 3
      • Lift the front of the drawer up.
      • Pull the drawer toward you to release the drawer from the drawer slides.
      • Remove the freezer drawer.
      Ask FixBot
    1. LG Refrigerator Model LFX25973 Freezer Light Replacement, Unfasten the freezer light: step 8, image 1 of 2 LG Refrigerator Model LFX25973 Freezer Light Replacement, Unfasten the freezer light: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the 22 mm‑long screw securing the freezer light.
      • Lower the front edge of the freezer light to access its connector.
      Ask FixBot
    2. LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the freezer light: step 9, image 1 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the freezer light: step 9, image 2 of 3 LG Refrigerator Model LFX25973 Freezer Light Replacement, Remove the freezer light: step 9, image 3 of 3
      • Squeeze the freezer light connector and pull it straight off to disconnect it.
      • Remove the freezer light.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 63
All Time: 378
