LG Refrigerator Model LFX25973 Control Board Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
74
All Time:
590
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the control board on your LG Model LFX25973 Refrigerator.
The control board is the brain of your LG refrigerator. It coordinates the function of the device, receiving inputs from various sensors, and controlling the function of other parts like fans, lights, alarms, and the refrigeration system components.
Failure of the control board can result in numerous problems ranging from complete failure of the appliance to odd alarms. Usually, the control board is one of the last components to check, because usually its failure is discovered through the elimination of other causes.
Parts
Tools
    1. LG Refrigerator Model LFX25973 Control Board Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser Fan Motor
      • Compressor Motor and Thermal Overload Device
      • Water Supply Valve Assembly
      Ask FixBot
    1. LG Refrigerator Model LFX25973 Control Board Replacement, Unfasten the control board cover: step 2, image 1 of 1
      • Use a Phillips screwdriver to remove the three 18.4 mm‑long screws securing the control board cover.
      Ask FixBot
    2. LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board cover: step 3, image 1 of 3 LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board cover: step 3, image 2 of 3 LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board cover: step 3, image 3 of 3
      • Tilt the top edge of the cover toward you and lift it off.
      Ask FixBot
    1. LG Refrigerator Model LFX25973 Control Board Replacement, Disconnect the control board: step 4, image 1 of 3 LG Refrigerator Model LFX25973 Control Board Replacement, Disconnect the control board: step 4, image 2 of 3 LG Refrigerator Model LFX25973 Control Board Replacement, Disconnect the control board: step 4, image 3 of 3
      • Squeeze and pull the eight connectors to disconnect them from the control board.
      Ask FixBot
    2. LG Refrigerator Model LFX25973 Control Board Replacement, Release the control board: step 5, image 1 of 3 LG Refrigerator Model LFX25973 Control Board Replacement, Release the control board: step 5, image 2 of 3 LG Refrigerator Model LFX25973 Control Board Replacement, Release the control board: step 5, image 3 of 3
      • Use your thumb to pry up and release the top left retaining clip securing the control board.
      • With your other hand, pull the top left corner of the control board out to loosen it.
      Ask FixBot
    3. LG Refrigerator Model LFX25973 Control Board Replacement: step 6, image 1 of 3 LG Refrigerator Model LFX25973 Control Board Replacement: step 6, image 2 of 3 LG Refrigerator Model LFX25973 Control Board Replacement: step 6, image 3 of 3
      • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
      Ask FixBot
    4. LG Refrigerator Model LFX25973 Control Board Replacement, Remove the control board: step 7, image 1 of 1
      • Lift the control board out by its edges and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 74
All Time: 590
