Up to 20% off select tools
LG Refrigerator Light Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
16
Past 7 Days:
95
Past 30 Days:
390
All Time:
3,358
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the refrigerator compartment light in an LG Refrigerator. The process involves removing the light unit, disconnecting it, and installing a new one. This guide is for LED based units.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
    1. LG Refrigerator Light Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Ask FixBot
    1. LG Refrigerator Light Replacement, Open the doors: step 2, image 1 of 3 LG Refrigerator Light Replacement, Open the doors: step 2, image 2 of 3 LG Refrigerator Light Replacement, Open the doors: step 2, image 3 of 3
      • Open both refrigerator doors fully.
      Ask FixBot
    1. LG Refrigerator Light Replacement, Remove the shelves: step 3, image 1 of 3 LG Refrigerator Light Replacement, Remove the shelves: step 3, image 2 of 3 LG Refrigerator Light Replacement, Remove the shelves: step 3, image 3 of 3
      • Lift up the front edge of the shelf to release it.
      • Unhook the shelf and remove it.
      • Repeat the last two steps for each shelf you wish to remove.
      Ask FixBot
    1. LG Refrigerator Light Replacement, Remove the light unit screws: step 4, image 1 of 1
      • Use a Phillips screwdriver to remove the screws that secure the light unit.
      Ask FixBot
    2. LG Refrigerator Light Replacement, Lower the light unit: step 5, image 1 of 2 LG Refrigerator Light Replacement, Lower the light unit: step 5, image 2 of 2
      • With both hands, pull down the front edge of the light unit until it pops free.
      • Don't try to fully remove the light unit yet, as it is still connected to the refrigerator by some wires.
      Ask FixBot
    3. LG Refrigerator Light Replacement, Disconnect the light unit: step 6, image 1 of 3 LG Refrigerator Light Replacement, Disconnect the light unit: step 6, image 2 of 3 LG Refrigerator Light Replacement, Disconnect the light unit: step 6, image 3 of 3
      • Pinch the light unit connector to release it and pull it out straight to disconnect.
      • Remove the light unit.
      Ask FixBot
    4. LG Refrigerator Light Replacement, Remove the light cover: step 7, image 1 of 3 LG Refrigerator Light Replacement, Remove the light cover: step 7, image 2 of 3 LG Refrigerator Light Replacement, Remove the light cover: step 7, image 3 of 3
      • Use a spudger to pry and release the two clips on the rear edge of the light.
      Ask FixBot
    5. LG Refrigerator Light Replacement: step 8, image 1 of 3 LG Refrigerator Light Replacement: step 8, image 2 of 3 LG Refrigerator Light Replacement: step 8, image 3 of 3
      • Use a spudger to pry and release the sides of the light cover from the light base.
      Ask FixBot
    6. LG Refrigerator Light Replacement: step 9, image 1 of 1
      • Separate the light base from the light cover.
      Ask FixBot
    7. LG Refrigerator Light Replacement, Remove the light module: step 10, image 1 of 1
      • Use a Philips head driver to remove the screws securing the light module.
      Ask FixBot
    8. LG Refrigerator Light Replacement: step 11, image 1 of 2 LG Refrigerator Light Replacement: step 11, image 2 of 2
      • Lift the light module out of the light base and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 95
Past 30 Days: 390
All Time: 3,358
