LG Refrigerator LFX25973 Display Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
85
All Time:
520
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the display board on your LG model LFX25973 refrigerator.
The display board shows the status of your refrigerator.
If it fails, a number of features on the dispenser may not work, including the ice type selection and temperature settings.
Gaining access to the display board takes some effort. You will have to remove the dispenser assembly, which can be somewhat difficult.
Tools
    1. LG Refrigerator LFX25973 Display Board Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser Fan Motor
      • Compressor Motor and Thermal Overload Device
      • Water Supply Valve Assembly
      Ask FixBot
    1. LG Refrigerator LFX25973 Display Board Replacement, Loosen the left door handle set screws: step 2, image 1 of 2 LG Refrigerator LFX25973 Display Board Replacement, Loosen the left door handle set screws: step 2, image 2 of 2
      • To remove the left door handle, first open the right door.
      • Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
      Ask FixBot
    2. LG Refrigerator LFX25973 Display Board Replacement, Remove the left door handle: step 3, image 1 of 2 LG Refrigerator LFX25973 Display Board Replacement, Remove the left door handle: step 3, image 2 of 2
      • Pull the left door handle straight off to remove it.
      Ask FixBot
    1. LG Refrigerator LFX25973 Display Board Replacement, Retaining clip locations: step 4, image 1 of 3 LG Refrigerator LFX25973 Display Board Replacement, Retaining clip locations: step 4, image 2 of 3 LG Refrigerator LFX25973 Display Board Replacement, Retaining clip locations: step 4, image 3 of 3
      • The dispenser assembly is secured by very strong clips, making it very difficult to remove. Take note of the clip locations shown in the photos:
      • Right side clips
      • Top clips
      • Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
      • During disassembly, you may break some of these clips. If you do, don't worry; the assembly does not need all the clips to be properly secured.
      Ask FixBot
    2. LG Refrigerator LFX25973 Display Board Replacement, Release the dispenser: step 5, image 1 of 3 LG Refrigerator LFX25973 Display Board Replacement, Release the dispenser: step 5, image 2 of 3 LG Refrigerator LFX25973 Display Board Replacement, Release the dispenser: step 5, image 3 of 3
      • Use a spudger to pry out the top edge of the dispenser assembly.
      • Once you've created a gap, use your fingertips to pull the edge downward.
      • Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
      • Optionally, you may use a flat-blade screwdriver to assist in this process. Be careful not to damage the door; you may scratch the door surface or dent the rim of the dispenser opening.
      Ask FixBot
    3. LG Refrigerator LFX25973 Display Board Replacement, Reposition the dispenser: step 6, image 1 of 3 LG Refrigerator LFX25973 Display Board Replacement, Reposition the dispenser: step 6, image 2 of 3 LG Refrigerator LFX25973 Display Board Replacement, Reposition the dispenser: step 6, image 3 of 3
      • Grasp the top edge of the dispenser assembly in the middle and pull outwards.
      • Continue prying and pulling around the perimeter of the assembly to release it.
      Ask FixBot
    4. LG Refrigerator LFX25973 Display Board Replacement: step 7, image 1 of 3 LG Refrigerator LFX25973 Display Board Replacement: step 7, image 2 of 3 LG Refrigerator LFX25973 Display Board Replacement: step 7, image 3 of 3
      • Grasp the assembly firmly and pull it out of the refrigerator door.
      • Don't try to pull the assembly completely off the refrigerator door. The assembly is still connected with numerous wires. These are mainly connected to the left side of the dispenser.
      Ask FixBot
    5. LG Refrigerator LFX25973 Display Board Replacement, Disconnect the dispenser: step 8, image 1 of 1
      • Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
      • Do not attempt to remove the four-wire connector from the board as it is not removable.
      Ask FixBot
    6. LG Refrigerator LFX25973 Display Board Replacement: step 9, image 1 of 2 LG Refrigerator LFX25973 Display Board Replacement: step 9, image 2 of 2
      • Squeeze and separate the two-wire harness connector and the four-wire harness connector.
      Ask FixBot
    7. LG Refrigerator LFX25973 Display Board Replacement, Unfasten the circuit board holder: step 10, image 1 of 3 LG Refrigerator LFX25973 Display Board Replacement, Unfasten the circuit board holder: step 10, image 2 of 3 LG Refrigerator LFX25973 Display Board Replacement, Unfasten the circuit board holder: step 10, image 3 of 3
      • Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
      • Lift and remove the circuit board holder from the dispenser assembly.
      Ask FixBot
    8. LG Refrigerator LFX25973 Display Board Replacement, Remove the dispenser: step 11, image 1 of 1
      • You can now remove the dispenser from the refrigerator.
      • The white circuit board holder can be suspended from the harness wires, as its weight is minimal.
      Ask FixBot
    1. LG Refrigerator LFX25973 Display Board Replacement, Release the ice dispensing switch wires: step 12, image 1 of 2 LG Refrigerator LFX25973 Display Board Replacement, Release the ice dispensing switch wires: step 12, image 2 of 2
      • Remove the tape securing wires to the rear of the dispenser assembly.
      Ask FixBot
    2. LG Refrigerator LFX25973 Display Board Replacement: step 13, image 1 of 2 LG Refrigerator LFX25973 Display Board Replacement: step 13, image 2 of 2
      • Remove the orange and white wires from the clip.
      Ask FixBot
    3. LG Refrigerator LFX25973 Display Board Replacement, Disconnect the ice dispensing switch: step 14, image 1 of 2 LG Refrigerator LFX25973 Display Board Replacement, Disconnect the ice dispensing switch: step 14, image 2 of 2
      • Pull the orange and white connector from the ice dispensing switch to disconnect it.
      Ask FixBot
    4. LG Refrigerator LFX25973 Display Board Replacement, Unfasten the display board: step 15, image 1 of 1
      • Use a Phillips driver to remove the eight 8 mm‑long screws securing the display board to the dispenser assembly.
      Ask FixBot
    5. LG Refrigerator LFX25973 Display Board Replacement, Remove the display board: step 16, image 1 of 3 LG Refrigerator LFX25973 Display Board Replacement, Remove the display board: step 16, image 2 of 3 LG Refrigerator LFX25973 Display Board Replacement, Remove the display board: step 16, image 3 of 3
      • Lift the display board off and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
40,642 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 85
All Time: 520
