Up to 20% off select tools
LG Rebel Screen Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
60
All Time:
13,147
Comments: 3
3 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This repair is to replace the screen on an LG Rebel. One might need to do this if the screen is cracked or unresponsive. If your screen is cracked be careful not to scratch yourself on the glass.
    1. LG Rebel Screen Replacement, Screen: step 1, image 1 of 1
      • Place the plastic opening tool into the indent on the side of the phone and lift the back off the device.
      Ask FixBot
    2. LG Rebel Screen Replacement: step 2, image 1 of 1
      • Put the plastic opening tool in at a downward angle and push it up so that the back pops off.
      Ask FixBot
    3. LG Rebel Screen Replacement: step 3, image 1 of 3 LG Rebel Screen Replacement: step 3, image 2 of 3 LG Rebel Screen Replacement: step 3, image 3 of 3
      • Insert the spudger into the small groove under one of the two black pieces.
      Ask FixBot
    4. LG Rebel Screen Replacement: step 4, image 1 of 2 LG Rebel Screen Replacement: step 4, image 2 of 2
      • Using either your finger or the spudger, gently lift the metal clasps until they are no longer connected to the back of the phone.
      Ask FixBot
    5. LG Rebel Screen Replacement: step 5, image 1 of 2 LG Rebel Screen Replacement: step 5, image 2 of 2
      • Using the metal spudger, push gently under the edge of the screen. You will hear the sound of the screen disconnecting from the glue.
      • Run the metal spudger around the entire perimeter of the phone , making sure to fully disconnect it from the glue.
      Ask FixBot
    6. LG Rebel Screen Replacement: step 6, image 1 of 1
      • Place suction cup on the screen.
      • Gently pull the screen up until it is completely disconnected from the phone.
      Ask FixBot
13 other people completed this guide.
Author
with
devan morales
561 Reputation
1 Guide authored
3 Guide Comments
Hey! Very helpful guide. I was just wondering if this works with replacing the digitizer and the screen, or is it just the screen? email ellym54@gmail.com, I would really appreciate the help!
Elly Murray - Reply Share
How do you know if you need to replace the digitizer as well? This Lg Rebel4 was dropped & screen cracked in 2 places however everything still works fine? Im not sure what a digitizer does though. Please help me so i understand because i dont want to mess this up.
Thanks guys
Blackhatchic1@gmail.com
BlackHat Chic - Reply Share
This is just to replace the glass panel over the actual display/digitizer, is it not?
If this is right, why does one need tom remove the back of the case and “undo the metal clips”?
What about gluing the new screen in? It DOES need glue, does it not? Otherwise, what seals it from the environment?
Mark Wallner - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 60
All Time: 13,147
