Up to 20% off select tools
LG Rebel Rear Camera Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
56
All Time:
1,056
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
This is a guide to replace a broken or damaged rear camera on the LG Rebel. This could be important if the camera became foggy or cracked. Be careful, as these are small parts and could be sharp if broken.
    1. LG Rebel Rear Camera Replacement, Rear Camera: step 1, image 1 of 2 LG Rebel Rear Camera Replacement, Rear Camera: step 1, image 2 of 2
      • Turn the phone on its side and locate the small groove.
      • Use the plastic opening tool to take the back cover off of the phone.
      Ask FixBot
    2. LG Rebel Rear Camera Replacement: step 2, image 1 of 3 LG Rebel Rear Camera Replacement: step 2, image 2 of 3 LG Rebel Rear Camera Replacement: step 2, image 3 of 3
      • Locate the small groove on the back of the phone near the bottom.
      • Use the metal spudger to pop open the black plastic covering.
      • Remove black plastic covering.
      Ask FixBot
    3. LG Rebel Rear Camera Replacement: step 3, image 1 of 2 LG Rebel Rear Camera Replacement: step 3, image 2 of 2
      • Use the metal spudger to pop up the black plastic covering near top of phone.
      • Remove the black plastic covering.
      Ask FixBot
    4. LG Rebel Rear Camera Replacement: step 4, image 1 of 3 LG Rebel Rear Camera Replacement: step 4, image 2 of 3 LG Rebel Rear Camera Replacement: step 4, image 3 of 3
      • Locate the connective pieces on the back of the phone.
      • Use the metal spudger to disconnect both of the connective pieces from the back.
      Ask FixBot
    5. LG Rebel Rear Camera Replacement: step 5, image 1 of 3 LG Rebel Rear Camera Replacement: step 5, image 2 of 3 LG Rebel Rear Camera Replacement: step 5, image 3 of 3
      • Flip the phone over so the screen is facing up.
      • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
      • Use the small suction cup to remove the screen.
      Ask FixBot
    6. LG Rebel Rear Camera Replacement: step 6, image 1 of 2 LG Rebel Rear Camera Replacement: step 6, image 2 of 2
      • Locate the black bumper at the bottom of the front of the phone.
      • Use the metal spudger to slide the bumper out.
      Ask FixBot
    7. LG Rebel Rear Camera Replacement: step 7, image 1 of 3 LG Rebel Rear Camera Replacement: step 7, image 2 of 3 LG Rebel Rear Camera Replacement: step 7, image 3 of 3
      • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
      • Slowly slide the motherboard out of the body of the phone.
      • Remove the motherboard.
      Ask FixBot
    8. LG Rebel Rear Camera Replacement: step 8, image 1 of 2 LG Rebel Rear Camera Replacement: step 8, image 2 of 2
      • Locate the rear camera on the motherboard.
      • Use the metal spudger to disconnect the connective piece at the base of the camera.
      • Remove the camera.
      Ask FixBot
Author
with
Emma Johnson
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 56
All Time: 1,056
