LG Rebel Motherboard Replacement
    1. LG Rebel Motherboard Replacement, Motherboard: step 1, image 1 of 2 LG Rebel Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Insert the plastic opening tool into the small groove on the side of the phone.
      • Remove the back cover with the plastic opening tool.
      Ask FixBot
    2. LG Rebel Motherboard Replacement: step 2, image 1 of 3 LG Rebel Motherboard Replacement: step 2, image 2 of 3 LG Rebel Motherboard Replacement: step 2, image 3 of 3
      • Insert the metal spudger into the small groove on the back of the phone.
      • Lift and remove the black plastic covering with the metal spudger.
      Ask FixBot
    3. LG Rebel Motherboard Replacement: step 3, image 1 of 2 LG Rebel Motherboard Replacement: step 3, image 2 of 2
      • Use the metal spudger to lift the remaining black plastic cover pieces.
      Ask FixBot
    4. LG Rebel Motherboard Replacement: step 4, image 1 of 3 LG Rebel Motherboard Replacement: step 4, image 2 of 3 LG Rebel Motherboard Replacement: step 4, image 3 of 3
      • Use the metal spudger to lift and disconnect the two connective pieces on the back of the phone.
      Ask FixBot
    5. LG Rebel Motherboard Replacement: step 5, image 1 of 3 LG Rebel Motherboard Replacement: step 5, image 2 of 3 LG Rebel Motherboard Replacement: step 5, image 3 of 3
      • Flip the phone, so that the screen is facing upwards.
      • Slide the metal spudger along the perimeter of the phone in order to break the entire seal.
      • Use the suction cup to lift and remove the screen.
      Ask FixBot
    6. LG Rebel Motherboard Replacement: step 6, image 1 of 2 LG Rebel Motherboard Replacement: step 6, image 2 of 2
      • Use the metal spudger to slide the black bumper out from the bottom of the phone.
      Ask FixBot
    7. LG Rebel Motherboard Replacement: step 7, image 1 of 3 LG Rebel Motherboard Replacement: step 7, image 2 of 3 LG Rebel Motherboard Replacement: step 7, image 3 of 3
      • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
      • Slowly slide the motherboard out of the body of the phone.
      • Remove the motherboard.
      Ask FixBot
2 other people completed this guide.
Justin Franklin
201 Reputation
1 Guide authored
1 Guide Comment
First time tearing apart a phone. His instructions are spot on. Pretty easy phone though.
Bruce Simmons - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 57
All Time: 2,025
