LG Rebel 4 LTE Disassembly
    1. LG Rebel 4 LTE Disassembly, Remove the Cover: step 1, image 1 of 2 LG Rebel 4 LTE Disassembly, Remove the Cover: step 1, image 2 of 2
      • Locate the indent on the back left side of the phone.
      • Insert the opening tool into the indent and pry until it pops.
      • Remove the backing.
      Ask FixBot
    2. LG Rebel 4 LTE Disassembly, Remove Internal Components: step 2, image 1 of 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: step 2, image 2 of 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: step 2, image 3 of 3
      • Use the spudger to pry the battery out.
      • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
      • Use your fingers to remove the sim card.
      Ask FixBot
    3. LG Rebel 4 LTE Disassembly, Remove Screws: step 3, image 1 of 3 LG Rebel 4 LTE Disassembly, Remove Screws: step 3, image 2 of 3 LG Rebel 4 LTE Disassembly, Remove Screws: step 3, image 3 of 3
      • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
      • There should be 12 screws in total.
      • Don't lose the screws!
      Ask FixBot
    4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: step 4, image 1 of 2 LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: step 4, image 2 of 2
      • Use the spudger to carefully pry the cover around the charging port.
      Ask FixBot
    5. LG Rebel 4 LTE Disassembly, Remove the Screen: step 5, image 1 of 3 LG Rebel 4 LTE Disassembly, Remove the Screen: step 5, image 2 of 3 LG Rebel 4 LTE Disassembly, Remove the Screen: step 5, image 3 of 3
      • Rotate the phone (view picture) to reveal the top corner of the phone.
      • Using a opening pick, pry in between the glass screen and the framing.
      Ask FixBot
    6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: step 6, image 1 of 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: step 6, image 2 of 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: step 6, image 3 of 3
      • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
      • Do not let the main camera fall out while removing the mother board.
      Ask FixBot
    7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: step 7, image 1 of 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: step 7, image 2 of 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: step 7, image 3 of 3
      • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
      • Disconnect the cable by gently pulling up on the component with your fingers.
      • Do not use a prying tool or screwdriver to disconnect the cable.
      Ask FixBot
    8. LG Rebel 4 LTE Disassembly, Remove the Camera: step 8, image 1 of 3 LG Rebel 4 LTE Disassembly, Remove the Camera: step 8, image 2 of 3 LG Rebel 4 LTE Disassembly, Remove the Camera: step 8, image 3 of 3
      • Separate the camera from the magnet by gently pulling up.
      Ask FixBot
    9. LG Rebel 4 LTE Disassembly, Disassembly Complete: step 9, image 1 of 1
      • Congratulations. You've successfully disassembled your device.
      • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
      • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
      Ask FixBot
JCJR
199 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 73
All Time: 1,124
