Up to 20% off select tools
LG Realm Plastic Midframe Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
87
All Time:
827
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Before continuing, make sure the device is powered down.
    1. LG Realm Plastic Midframe Replacement, Battery: step 1, image 1 of 2 LG Realm Plastic Midframe Replacement, Battery: step 1, image 2 of 2
      • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
      • Use nail to loosen case on all four sides. Once loose, remove back case.
      Ask FixBot
    2. LG Realm Plastic Midframe Replacement: step 2, image 1 of 1
      • Insert thumbnail into tab below battery.
      • Pull away from phone and remove.
      Ask FixBot
    1. LG Realm Plastic Midframe Replacement, Plastic Midframe: step 3, image 1 of 2 LG Realm Plastic Midframe Replacement, Plastic Midframe: step 3, image 2 of 2
      • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
      Ask FixBot
    2. LG Realm Plastic Midframe Replacement: step 4, image 1 of 1
      • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
      Ask FixBot
6 other people completed this guide.
Author
with
Ryan St Martin
785 Reputation
4 Guides authored
Marist, Team 1-5, Laflen Spring 2016 Member of Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 87
All Time: 827
