Up to 20% off select tools
LG Realm Motherboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,904
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
Before continuing, make sure the device is powered down. Also make sure that the battery and back casing are removed.
    1. LG Realm Motherboard Replacement, Battery: step 1, image 1 of 2 LG Realm Motherboard Replacement, Battery: step 1, image 2 of 2
      • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
      • Use nail to loosen case on all four sides. Once loose, remove back case.
      Ask FixBot
    2. LG Realm Motherboard Replacement: step 2, image 1 of 1
      • Insert thumbnail into tab below battery.
      • Pull away from phone and remove.
      Ask FixBot
    1. LG Realm Motherboard Replacement, Plastic Midframe: step 3, image 1 of 2 LG Realm Motherboard Replacement, Plastic Midframe: step 3, image 2 of 2
      • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
      Ask FixBot
    2. LG Realm Motherboard Replacement: step 4, image 1 of 1
      • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
      Ask FixBot
    1. LG Realm Motherboard Replacement, Rear Facing Camera: step 5, image 1 of 1
      • Locate the rear facing camera.
      • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
      Ask FixBot
    2. LG Realm Motherboard Replacement: step 6, image 1 of 1
      • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
      Ask FixBot
    1. LG Realm Motherboard Replacement, Front Facing Camera: step 7, image 1 of 1
      • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
      Ask FixBot
    2. LG Realm Motherboard Replacement: step 8, image 1 of 1
      • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
      Ask FixBot
    1. LG Realm Motherboard Replacement, Motherboard: step 9, image 1 of 1
      • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
      Ask FixBot
    2. LG Realm Motherboard Replacement: step 10, image 1 of 2 LG Realm Motherboard Replacement: step 10, image 2 of 2
      • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
      Ask FixBot
    3. LG Realm Motherboard Replacement: step 11, image 1 of 1
      • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
      Ask FixBot
    4. LG Realm Motherboard Replacement: step 12, image 1 of 1
      • Using the plastic opening tool, carefully remove the motherboard from the phone.
      Ask FixBot
4 other people completed this guide.
Author
with
Ryan St Martin
785 Reputation
4 Guides authored
Marist, Team 1-5, Laflen Spring 2016 Member of Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,904
