Tools
Introduction
Go to step 1 ↓This guide is made to help remove the screen from your phone if you are having problems with it or need to replace it. Be careful while removing the back plating, mid plating, and screen. If this is your first time removing a touchscreen seek the help of a professional, because you may accidentally caused the image on the screen to after you put the phone back together.
Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
12 other people completed this guide.
9 Guide Comments
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Did you ever figure out if there the same or separate. I'm needing to do the same.
Where do I buy the glass panel?
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
