Up to 20% off select tools
LG Power SD Card Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
87
All Time:
1,126
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is made to help remove the SD card from your phone if you are having problems with it or need to replace it. The only real hazard involving this step is removing the back plating of your phone.
    1. LG Power SD Card Replacement, SD Card: step 1, image 1 of 1
      • Slide a plastic opening tool between the back and front panel at the bottom.
      Ask FixBot
    2. LG Power SD Card Replacement: step 2, image 1 of 2 LG Power SD Card Replacement: step 2, image 2 of 2
      • Carefully pop the back panel off and place it to the side.
      Ask FixBot
    3. LG Power SD Card Replacement: step 3, image 1 of 1
      • While looking at the phone from the back, locate the SD card slot on the lower right side.
      • If the slot is empty, insert your new SD card. If not, remove the old SD card and replace it with the new SD card.
      Ask FixBot
Author
with
Nadia Wilson
925 Reputation
4 Guides authored
USF Tampa, Team 4-6, Lacy Spring 2016 Member of USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 87
All Time: 1,126
