Up to 20% off select tools
LG Power Motherboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
102
All Time:
1,925
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is made to help remove the motherboard from your phone if you are having problems with it or need to replace it. The only real hazard involving this step is removing the back and mid plating of your phone.
    1. LG Power Motherboard Replacement, Battery: step 1, image 1 of 2 LG Power Motherboard Replacement, Battery: step 1, image 2 of 2
      • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
      • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
      Ask FixBot
    2. LG Power Motherboard Replacement: step 2, image 1 of 2 LG Power Motherboard Replacement: step 2, image 2 of 2
      • Carefully pop the back panel off and place it to the side.
      Ask FixBot
    3. LG Power Motherboard Replacement: step 3, image 1 of 2 LG Power Motherboard Replacement: step 3, image 2 of 2
      • Use the thumb tab to remove the battery.
      Ask FixBot
    1. LG Power Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
      Ask FixBot
    2. LG Power Motherboard Replacement: step 5, image 1 of 2 LG Power Motherboard Replacement: step 5, image 2 of 2
      • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
      • Place the mid panel to the side.
      Ask FixBot
    3. LG Power Motherboard Replacement: step 6, image 1 of 3 LG Power Motherboard Replacement: step 6, image 2 of 3 LG Power Motherboard Replacement: step 6, image 3 of 3
      • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
      • The motherboard will then be free from the phone.
      Ask FixBot
3 other people completed this guide.
Author
with
Nadia Wilson
925 Reputation
4 Guides authored
USF Tampa, Team 4-6, Lacy Spring 2016 Member of USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 102
All Time: 1,925
