Up to 20% off select tools
LG Power Battery Replacement
Views: 9.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
89
Past 30 Days:
189
All Time:
9,867
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is made to help remove the battery from your phone if you are having problems with it or need to replace it. The only real hazard involving this step is removing the back plating of your phone.
    1. LG Power Battery Replacement, Battery: step 1, image 1 of 2 LG Power Battery Replacement, Battery: step 1, image 2 of 2
      • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
      • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
      Ask FixBot
    2. LG Power Battery Replacement: step 2, image 1 of 2 LG Power Battery Replacement: step 2, image 2 of 2
      • Carefully pop the back panel off and place it to the side.
      Ask FixBot
    3. LG Power Battery Replacement: step 3, image 1 of 2 LG Power Battery Replacement: step 3, image 2 of 2
      • Use the thumb tab to remove the battery.
      Ask FixBot
Author
with
Nadia Wilson
925 Reputation
4 Guides authored
USF Tampa, Team 4-6, Lacy Spring 2016 Member of USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 89
Past 30 Days: 189
All Time: 9,867
