LG Phoenix 2 Outer Trim Replacement
    1. LG Phoenix 2 Outer Trim Replacement, Outer Trim Casing: step 1, image 1 of 2 LG Phoenix 2 Outer Trim Replacement, Outer Trim Casing: step 1, image 2 of 2
      • Insert a fingernail in the notch on the bottom right corner of the phone.
      • Pop off the back cover off of your device.
      Ask FixBot
    2. LG Phoenix 2 Outer Trim Replacement: step 2, image 1 of 2 LG Phoenix 2 Outer Trim Replacement: step 2, image 2 of 2
      • Insert a fingernail in the notch under the battery.
      • Remove the battery.
      Ask FixBot
    3. LG Phoenix 2 Outer Trim Replacement: step 3, image 1 of 2 LG Phoenix 2 Outer Trim Replacement: step 3, image 2 of 2
      • Insert the opening tool under the bottom cover.
      • Pop out the bottom cover.
      Ask FixBot
    4. LG Phoenix 2 Outer Trim Replacement: step 4, image 1 of 1
      • Remove eight 3mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    5. LG Phoenix 2 Outer Trim Replacement: step 5, image 1 of 2 LG Phoenix 2 Outer Trim Replacement: step 5, image 2 of 2
      • Insert the opening tool in between the silver trim and the screen.
      • Pop off the trim.
      Ask FixBot
2 other people completed this guide.
Sarah Popp
395 Reputation
3 Guides authored
IUPUI, Team S7-G7, Wilson Fall 2018 Member of IUPUI, Team S7-G7, Wilson Fall 2018
IUPUI-WILSON-F18S7G7
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 68
All Time: 607
